question about nitrous controllers
i'm currently in the market for a nitrous controller and have a question to ask before i buy.
in regards to the N.O.S. controllers, both the time based and fully programable:
just like any other nitrous setup, i'm assuming that they operate off of a full-throttle/microswitch or perhaps TPS voltage...........both of the N.O.S. controllers use the idea of starting out with a certain percentage and then "ramp up" to 100% flow over a certain amount of time, adjustable by the user. my question is, will the "ramp up" process start over each time i shift, i.e. the conroller loses the signal from the full throttle switch or tps voltage?
thanks in advance!!
thanks in advance!!
LOL JSPIN DADDY PIMP SHIZZLE FO RIZZLE. lol Just swipe an ADTD off of a Heavy and turn it into a nitrous controller. LMAO. loadmasters only use that **** for solitaire anyways. LMAO.
Ratliff
Ratliff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aut0tek »</TD></TR><TR><TD CLASS="quote">LOL JSPIN DADDY PIMP SHIZZLE FO RIZZLE. lol Just swipe an ADTD off of a Heavy and turn it into a nitrous controller. LMAO. loadmasters only use that **** for solitaire anyways. LMAO.
Ratliff</TD></TR></TABLE>
*shakes head*
any other input, pleeeeease?
*shakes head*
well the range is 0-10sec, in which gear would you stay in for more than a few seconds? just common sense would tell me it doesnt restart.
not to mention you'll be in each gear a different amount of time so if you timed it to work good in 4th gear, 1st would suck.
call or email NOS to get a definite answer.
