cv shaft replacement
Old Aug 16, 2004 | 02:55 PM
hondaowner's Avatar
Default cv shaft replacement
Guys,
I got a Civic 97 Automatic transmission and both front axles have the outer boot torn. So bought a remanufactuerd axles from Autozone. Just wondering if i should do it myself or give it to a shop.
Here are my questions if i were to do it.
- Should i do both at once ? or can i do it one in one week and another in another week ?
- Does the transmission to be flushed when ever i do each axle ? if so there probably is an advantage doing all at once right ?
Do folks recommend doing it myself ? I have successfully did my brake rotors and pads myself with the guidance from this site. That was great.
Thanks
Old Aug 16, 2004 | 02:58 PM
Tyree's Avatar
Default Re: cv shaft replacement (hondaowner)
If you search there is a good writeup on axle replacment. If you are fairly good with tools you should be able to do it. I would replace both at the same time.
stevenDAtegra
Nov 19, 2008 11:43 AM
tekkynikality
Oct 27, 2004 02:12 PM
c8r9x
13
Aug 8, 2003 11:46 AM
type Gendy
Jan 19, 2003 06:18 PM
Prelussion
Nov 15, 2001 12:51 PM
