to those who shift past redline
Old Aug 16, 2004 | 11:02 AM
BluePrelude01's Avatar
Default to those who shift past redline
Hi, to those who shift past redline, does the engine produce a horrible smell?
I searched and i found this https://honda-tech.com/zerothread?id=566553 but nobody mentioned if any odor is produced when shifting at really high rpm.
The reason I ask this is because I (unintentionally) shifted at 8k rpm and was scared shitless. But then I read that thread and dont feel that bad now, but my engine did produce a bad smell right after the shift and after a couple hours, the smell was slightly still there. It drives pefectly fine so far, I'm not sure about noise. I thought I heard something different, but when I went outside to listen I didnt hear anything unusual.
Old Aug 16, 2004 | 11:05 AM
98TypeSH's Avatar
Default Re: to those who shift past redline (BluePrelude01)
did you ride the clutch? the smell is probably the clutch, kinda smells like a combo of burt plastic/rubber.
Old Aug 16, 2004 | 11:29 AM
LudeyKrus's Avatar
It was probably either a bit of clutch burning or some oil being burnt from the rev's.
Don't worry.
Old Aug 16, 2004 | 11:33 AM
uncle's Avatar
I wouldn't worry. I've bounced mine of the 8.5k rev limiter a couple times and haven't had any problems yet.
Old Aug 16, 2004 | 11:56 AM
Default Re: to those who shift past redline (uncle)
Thanks, that's good to hear. But I dont believe I was riding the clutch. What happened was I was driving in a lane and was already at 6500ish rpm and this car just cuts me off, so I swerved over to the next lane, and by the time I looked down and changed gear, I saw it dropping from 8k. Thanks again for the quick replies.
Old Aug 16, 2004 | 12:06 PM
98TypeSH's Avatar
yea, 8K on the tach is fuel cut, tis a weird feeling isnt it? You should be fine, if you were mashing the gas and miss-shifted it would be a different story. no worries.
Old Aug 16, 2004 | 12:33 PM
kellyk75's Avatar
Default Re: to those who shift past redline (98TypeSH)
Keep in mind that there is a bit of a factor of safety. 8000 rpm = 7600 true rpm. The dash above v-tec is conservative. Ask anyone who has a VAFC or had dyno'd.
You should be fine. I would NEVER hit the limiter though.
Old Aug 16, 2004 | 02:22 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">did you ride the clutch? the smell is probably the clutch, kinda smells like a combo of burt plastic/rubber.</TD></TR></TABLE>
wurd
Old Aug 16, 2004 | 05:26 PM
UA6 BALLER STATUS's Avatar
Default Re: to those who shift past redline (SKDRCR)
lol that was my old thread, Ive been taking it to 8k on the stock tach daily and no problems to this day. I wouldnt worry about it. its a Honda.
LSBeast
62
Jan 20, 2023 09:58 AM
TJ95CivicEG
10
Jul 24, 2005 04:03 AM
TypeRlove
Apr 19, 2005 07:38 PM
94GSRNewbie
Aug 4, 2001 11:48 PM
