How the hell did u tap the back of ure b series blocks(knock sensor location)
Old Aug 15, 2004 | 10:52 PM
2SlowDC's Avatar
Default How the hell did u tap the back of ure b series blocks(knock sensor location)
alright im in the process of trying to redo my oil feed line because my current on is too short and goes over the valve cover but I cant even unscrew it because i cant see it or hardly even gain access to it.
what size line is it that feeds to the turbo?
Old Aug 16, 2004 | 03:03 AM
eg6T's Avatar
Default Re: How the hell did u tap the back of ure b series blocks(knock sensor location) (lsVtec...)
just extend the line you already have,buy a connector from earls and then connect it to another line...my oil feed line is -3an,thats usually what they are.
Old Aug 16, 2004 | 04:11 AM
White Smoke's Avatar
i my honda
Global Mod
The fitting size or line size?
Old Aug 16, 2004 | 12:40 PM
eg6T's Avatar
Default Re: How the hell did u tap the back of ure b series blocks(knock sensor location) (si2die4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si2die4 &raquo;</TD></TR><TR><TD CLASS="quote">The fitting size or line size?
fitting and line are -3an
Old Aug 16, 2004 | 12:49 PM
toolowsol's Avatar
Default Re: How the hell did u tap the back of ure b series blocks(knock sensor location) (eg6T)
I sure hope you aren't tapping the knock sensor for oil!!!!! No oil there, just a threaded hole to screw the knock sensor into
Old Aug 16, 2004 | 01:33 PM
donkiman's Avatar
Default Re: How the hell did u tap the back of ure b series blocks(knock sensor location) (toolowsol)
yeah that hole you are refering to is definetly not the knock sensor. it is most likely the stock oil sensor (which you need in order for the computer to let vtec kick in.) It bassically lets the ecu know that your motor has oil. so you can do 1 of 2 things. have a T fitting so you can have your oil feedline and oil sensor plugged in or just keep it as it was stock and blitz makes this piece that goes on behind your oil filter and it has to perfectly angled outlets for any type of oil signal. thats personally what i used for my oil feed and oil pressur gauge. Any real performance shop that does work there should carry this.
Old Aug 16, 2004 | 01:35 PM
donkiman's Avatar
Default Re: How the hell did u tap the back of ure b series blocks(knock sensor location) (donkiman)
I wish i could supply a picture to show you exactly what im talking about but i just got to college and have no pics saved. but if you have any quesitons feel free to ask.
Old Aug 16, 2004 | 10:43 PM
2SlowDC's Avatar
haha im stupid. ok oil sensor location. anywho im just wonder how u guys even work behind there to tap the sensor. i have a b18b non vtec and have the oil line already running off a "T" connector but i took off my turbo for awhile to get it rebuilt and i have no plugs for the line. so what im trying to do is take the "T" connector off and just put the oil sensor back in.
Jimster480
Mar 20, 2009 09:26 PM
a1320addict
Mar 21, 2006 09:13 PM
Si Shane
Aug 2, 2005 10:32 PM
Tad
Feb 23, 2004 04:40 PM
