B18c1 with 6psi, has a miss during boost... help
Old Aug 15, 2004 | 07:34 PM
JDMs1eeper's Avatar
Default B18c1 with 6psi, has a miss during boost... help
Writing this for my friend, please help him out. thank you.
setup
Delsol Si
B18c1
JDM B16a ecu
Skunk2 Manifold
Equal length Manifold
Tial wastegate 6psi
greddy types BOV
t304e turbo
2.5in. charge pipes
johnnyracecar intercooler
2.5 to 3 inch down pipe
3in. full exhaust
RC440's
Walbro Pump
VAFC2
NGK Iridium Spark Plugs
Ran 13.2 @ 107 on 6psi on street tires w/ stock injectors and FMU. Now with Injectors, pump and SAFC it has a terrible miss... please help
When i had stock injectors and FMU w/ stock pump the car would pull the whole time while in boost. When i took the FMU off and installed the injectors, pump it had a bad miss when in WOT. I then installed the VAFC2 and it still has this problem. I set it to -30 across the board, still same problem, and 0 across the board. when boost hits it gets a flat spot and has a terrible miss during the pool. any clue on this? My A/F gauge reads lean diring the miss even when more fuel is added. Thanks for anyone that can help troubleshoot this . thanks.
Old Aug 15, 2004 | 08:02 PM
flip1199's Avatar
Default Re: B18c1 with 6psi, has a miss during boost... help (Typesi2nv)
what are the plugs gapped at?
Old Aug 15, 2004 | 08:38 PM
boost junky 71's Avatar
Default Re: B18c1 with 6psi, has a miss during boost... help (flip1199)
-30 is really rich. Check your plugs they'll give you an idea whats happening. The reason why it missed with just the injectors and pump is because you added twice as much fuel. 240-440 is almost double. I'm surprised it even ran. Now you've added the VAFC to control your new injectors. Try -40 to about 4k and add more fuel say -35 towards the top end. Car should run better like this. Make sure everything is connected right and soldered. Fine tune it as needed. Check other peoples settings and you'll get an idea what to use for your own.
Old Aug 15, 2004 | 11:58 PM
Cimburke23's Avatar
Default Re: B18c1 with 6psi, has a miss during boost... help (e'sd16)
well its my car and actually i had the pump in w/ stock inj. and FMU also because it would run REALLY REALLY lean up top w/o the pump. if i set the vafc at anything below -27 at idle, it idles REALLY REALLY lean, like almost completely off the a/f gauge, i had bkr7e NGK plugs gapped at .030, and it had the same miss, i forgot to gap the iridiums tho, if anyone can let me know their opinion of the iridiums and boost, please help cuz i know not to run platinums w/ boost, im actually thinking of going back to stock injectors and FMU and see if i can richen it up up top to make it run nice and just sell the 440's. also i have a 99 DX hatch that ran a 18.4 stock w/ intake and exhaust, this seems REALLY slow to me as ive seen an S model 97 del sol run a mid 16 stock, but my timing was retarded almost completely, anyone have an idea on that id like ur input also
Old Aug 16, 2004 | 02:22 PM
JDMs1eeper's Avatar
Default Re: B18c1 with 6psi, has a miss during boost... help (Cimburke23)
Hopefully some1 can help him out w/ this. He's a good guy and has been threw a lot. He needs good luck for now on
Old Aug 16, 2004 | 05:07 PM
Cimburke23's Avatar
ok well i put stock injectors back in and the vortech 12:1 fmu, and it runs great, explain this to me PLEASE!!!! anyone have info, HELP HELP HELP. thanks in advance anyway
Old Aug 16, 2004 | 05:18 PM
Could list your complete setting for the VAFC? The more info the better.
toolowsol's Avatar
it is all in the tuning, you have it running rich as hell on the vafc, of coarse it will have misfires and run shitty, lean it out some.
Old Aug 16, 2004 | 06:31 PM
Cimburke23's Avatar
Default Re: B18c1 with 6psi, has a miss during boost... help (toolowsol)
well the settings were -27 at idle because thats where it isnt too lean at idle, even though some people seem to not believe that, saying that i have it set too rich, but after that i had it set to -20 all the way up to 9K on wide and narr. throttle, then it seemed to lean out up top so i richened it to 0 from 4K on up to 9K and that didnt seem to do anything
Modified by Cimburke23 at 12:07 AM 8/17/2004
Old Aug 17, 2004 | 03:15 AM
What kind of air fuel gauge are using? You were running it pig rich that's causing the misfire.
Old Aug 17, 2004 | 04:44 AM
kell211's Avatar
also, are you throwing a cel. and if so reset it. having the vafc at -27 and -20, your probably throwing the map code also. and if you dont reset that, your car will run like ****.
Old Aug 17, 2004 | 06:01 AM
MrBui's Avatar
sounds like he's using a narrow band a/f gauge
Old Aug 17, 2004 | 06:50 AM
SOHC_MShue's Avatar
the only way to know what is going on is to get a wideband on that thing. Narrowband AF gauges are extremely inaccurate. Have you pulled your plugs to see what color they were? If they are fairly white then it may be a sign that you are running lean.
Old Aug 17, 2004 | 12:30 PM
Default Re: B18c1 with 6psi, has a miss during boost... help (SOHC_MShue)
And if there black your running rich. I'll bet there black with those settings.
Old Aug 19, 2004 | 09:55 AM
Cimburke23's Avatar
NO WHERE NEAR BLACK, more of a light brown to white color, and i can just tell when it leans out and richens up at idle because it tries to cut off either way, even using the narrowband a/f i just dont know what to do with this thing its really pissin me off
Old Aug 19, 2004 | 12:45 PM
JDMs1eeper's Avatar
give it to me, i'll make it a nice hope
Old Aug 19, 2004 | 12:49 PM
toolowsol's Avatar
how can you magically tell if it is rich or lean? GET A WIDE BAND!
Old Aug 19, 2004 | 02:05 PM
Something is not right. Did you solder everything? Were you using a missing link before by any chance and didn't remove it once you put the VAFC in? I'm just trying to narrow it down.
Old Aug 19, 2004 | 07:31 PM
Cimburke23's Avatar
actually i removed it, then it was throwing a MAP code, what do i do then? i now put the 440's back in and took the fmu off after changing plug wires and it runs great, settings are: -27 at idle, and -20 from there on, runs excellent, but i still have the missing link on it for now just so it doesnt throw a code, let me know what i should do, and wanting to up the boost, let me know what you people think a STOCK gsr can hold. thanks
Old Aug 20, 2004 | 03:36 PM
I know your running alright with the missing link but the VAFC needs to see boost.
I'm looking for a link for you to read. I posted the wrong the one.
Modified by e'sd16 at 9:06 PM 8/23/2004
Old Aug 22, 2004 | 01:53 PM
Cimburke23's Avatar
thanks man, but the link doesnt work
Old Aug 27, 2004 | 11:37 AM
TurboEH2's Avatar
i know what u should do. pull ur entire turbo set-up off and put it on my hatch before u ship it overseas to me.
ever think maybe its the tuner not the tunee? lol j/j ill never question your knowledge of honda
Old Aug 28, 2004 | 12:34 AM
JDMs1eeper's Avatar
Default Re: B18c1 with 6psi, has a miss during boost... help (LSvtecEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtecEH2 &raquo;</TD></TR><TR><TD CLASS="quote">i know what u should do. pull ur entire turbo set-up off and put it on my hatch before u ship it overseas to me.
ever think maybe its the tuner not the tunee? lol j/j ill never question your knowledge of honda </TD></TR></TABLE>
Yeah i know, chris invented the game called "honda" good ****.
But sorry about this jason, his turbo kit may be on my hatch soon
he tell you what he dyno'd at last week? 241whp and it was still climbing on only 6psi. Pretty bad ***
Old Aug 28, 2004 | 02:22 AM
TurboEH2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Typesi2nv &raquo;</TD></TR><TR><TD CLASS="quote">
he tell you what he dyno'd at last week? 241whp and it was still climbing on only 6psi. Pretty bad *** </TD></TR></TABLE>
yeah, he is honda. but hes so young. LOL. yeah i know about the turbo situation besides i want a smaller turbo. quicker spool with less boost. im just in it to win it. yeah i heard about the dyno session also. thats insane, if only he had a good tune and a lighter shell, hat ****** would be runnin what he wants. ive got this bad image of him building a true "racecar" not like our 1 week project car we built (it still was hella quick, even on 3 cyl). u know chris lol
Old Aug 29, 2004 | 10:17 AM
JDMs1eeper's Avatar
yeah, he is honda. but hes so young. LOL. yeah i know about the turbo situation besides i want a smaller turbo. quicker spool with less boost. im just in it to win it. yeah i heard about the dyno session also. thats insane, if only he had a good tune and a lighter shell, hat ****** would be runnin what he wants. ive got this bad image of him building a true "racecar" not like our 1 week project car we built (it still was hella quick, even on 3 cyl). u know chris lol</TD></TR></TABLE>
Yeah lol, I told him... "chris, you know taht swap in my car w/ slicks and a good run would be 11's??" he looked at me and then the sol and said he wished he had an eg again lol.
I road in Chris's (Big Black Chris from Richmond) in his EF LS turbo last night. its fast as hell but has a lot of traction issues, lol i still think i could take him on a richmond sized corse (less than a 1/4) lol... Its 9.5psi on the same turbo kit as Chris's Delsol GSR so it just rips, He doesnt catch traction until mid 4th, witch comes VERY quick, He would drive on his BFG's but last time he went out there with them he wrecked it into the median on i95 comeing home when it started raining.
eGeeHaTcH
Jan 16, 2005 02:43 PM
B20-T
Mar 3, 2003 07:29 AM
jmad08
Jul 30, 2002 10:02 AM
99civicdx
Jun 27, 2002 02:27 PM
