is there a gasket between the WG and manifold ?
Old Dec 1, 2001 | 06:18 PM
D-SPEED's Avatar
Default is there a gasket between the WG and manifold ?
yay or nay ?
Old Dec 1, 2001 | 06:36 PM
Jared's Avatar
Default Re: is there a gasket between the WG and manifold ? (D-SPEED)
yes
Old Dec 1, 2001 | 07:04 PM
SiR Kid's Avatar
New User
Default Re: is there a gasket between the WG and manifold ? (Jared)
yes, it's a graphite material type crush gasket.
Old Dec 1, 2001 | 07:23 PM
TurboSedan's Avatar
New User
Default Re: is there a gasket between the WG and manifold ? (SiR Kid)
Boom, right on it!!!!
Old Dec 1, 2001 | 08:53 PM
D-SPEED's Avatar
Default Re: is there a gasket between the WG and manifold ? (97CivicFerio)
this is between the WG flange and mani i assume ? what about between the WG and the flange ?....i dont even know how those two connect together.
where can i get this wg->mani gasket ?
Old Dec 2, 2001 | 07:41 AM
GSR_Dude's Avatar
Think you need the fire ring gasket.
http://www.turboneticsinc.com/catalog/wastegate.html
Old Dec 2, 2001 | 06:46 PM
Flamenco-T's Avatar
Default Re: is there a gasket between the WG and manifold ? (GSR_Dude)
I don;t have any, just make sure you botj surfaces are flat and clean, tighten it up, in a day or so, the carbon will seals up all the pinhole leaks....
I burned out two gasket already....
Old Dec 2, 2001 | 06:47 PM
jbsadler's Avatar
New User
Default Re: is there a gasket between the WG and manifold ? (Flamenco-T)
same here...no gasket
Old Dec 2, 2001 | 06:59 PM
GSR_Dude's Avatar
Yeah, the ones that come with the Tial wastegate are pretty crappy. Burnt them out in no time.
Old Dec 3, 2001 | 12:42 AM
liam821's Avatar
25 Year Member
i blew mine out too...i got some new ones with the metal ring inside and havent had a problem since. It was $5 for a new one.
liam
Old Dec 3, 2001 | 04:23 AM
4dGSR at work's Avatar
Default Re: is there a gasket between the WG and manifold ? (liam821)
my gasket broke too quick
all ya gotta do is run a lil rich for a bit and build up a carbon seal....
also.... its a tight seal w/o it
IloveNewt
Jan 21, 2004 06:20 PM
XBoostedAccordX
Oct 18, 2003 09:31 PM
SpeedMonkeyRacing
Oct 9, 2003 12:33 PM
Snafu-Si
May 8, 2003 02:03 PM
dragnGSR
May 11, 2002 08:55 AM
