what do u use to cut sheet metal?
Old Aug 15, 2004 | 01:46 PM
flip1199's Avatar
Default what do u use to cut sheet metal?
besides scissors what are some non-exspensive tools u use to cut sheet metal?
Old Aug 15, 2004 | 01:58 PM
paulzy's Avatar
Default Re: what do u use to cut sheet metal? (flip1199)
I use sheet metal shears
then when the job gets too big, I borrow the plasma cutter
Old Aug 15, 2004 | 02:00 PM
flip1199's Avatar
Default Re: what do u use to cut sheet metal? (paul vang)
what would u use to cut in oval in a piece of sheet metal?
Old Aug 15, 2004 | 02:02 PM
Wes V's Avatar
Man, that all depends on what you are doing and how much you care!!
Real thin flat sheet stock; tin snips. Get both left and right hand snips. (ya, there really is such a thing)
Medium thickness flat stock; I like to use my Mikita 4" grinder with a cut-off wheel on it.
Thick stuff; I use the cutting torch (I don't have a plasma cutter)
Cutting out a section of the body; I once again would use the Mikita with cut-off wheel.
If I had to cut a door post (with inner panels); I'd borrow a Saws-All. Most contractors have one.
Cutting a frame rail and didn't care about how it looks (as if I was working at a junk yard); The cutting torch. Quick and ugly.
Wes
Old Aug 15, 2004 | 02:24 PM
2point2's Avatar
you can make a 'quick and ugly' cut with a tourch and then fix it up with a nice big bench grinder. on thicker stuff that is..
Old Aug 15, 2004 | 08:19 PM
Qfactor's Avatar
Default Re: (2point2)
Plasma cutter, nice but they sell about 1000 up.
Old Aug 15, 2004 | 08:33 PM
RenoRacing's Avatar
Default Re: (Qfactor)
electric shears can handle up to about 18ga and cut a pretty nice line, nothing to curvy or fancy but quick that's for sure!
Old Aug 16, 2004 | 12:21 AM
.Ash's Avatar
torches can easily warp the thinner stuff. i usually use air shears or an air nibbler.
Old Aug 16, 2004 | 06:21 AM
ndustryalGSR's Avatar
Default Re: (Ashish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RenoRacing &raquo;</TD></TR><TR><TD CLASS="quote">electric shears can handle up to about 18ga and cut a pretty nice line, nothing to curvy or fancy but quick that's for sure!</TD></TR></TABLE>
Electric shears rock -- they look similar to a hand-held jigsaw, but have shears instead of a blade. You can get them at most hardware/home improvement stores.
If you have a compressor, air shears are great, too.
Old Aug 16, 2004 | 09:03 AM
zc911's Avatar
i haave a band saw, but a jigsaw with a metal balde will work nicely
Old Aug 16, 2004 | 01:32 PM
2point2's Avatar
Default Re: (ndustryalGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndustryalGSR &raquo;</TD></TR><TR><TD CLASS="quote">Electric shears rock</TD></TR></TABLE>
how thick can you go with those? never seen them in action before..
Old Aug 16, 2004 | 01:47 PM
nonsense's Avatar
these ones say up to 18GA
http://www.harborfreight.com/c...46681
Old Aug 16, 2004 | 04:53 PM
Thinkmoto's Avatar
Default Re: (nonsense)
torch, plasma cutter, Milling machine, cut off wheels, die grinders......
Old Aug 16, 2004 | 05:56 PM
SpeedDreamz.com's Avatar
Default Re: (Thinkmoto)
For curvy cuts use a makita electric nibbler.
fightingirish61
Paint and Body
Feb 5, 2014 06:08 PM
Immanuel
Dec 26, 2005 06:19 AM
Ca$h
Welding / Fabrication
Jan 13, 2005 02:22 PM
andypandy
Apr 12, 2004 01:28 AM
00b18b
Oct 5, 2001 05:13 PM
