A/C Help for 90 EX Coupe
Old Aug 15, 2004 | 01:13 PM
pothole0222's Avatar
Default A/C Help for 90 EX Coupe
Ok guys, here's my problem...
Either my A/C compressor or the compressor clutch is shot. Not locked-up yet, but making a terrible racket. Just as a TEMPORARY fix, I want to just bypass the compressor by removing the belt. Problem is, as I'm sure you know, the A/C Compressor and alternator are operated by the same belt. Can I buy a shorter belt and leave the compressor in place for the time being, or will this create clearance issues? Also... anyone have any idea what shorter belt I could use??? Thanx in advance!!!
--Kevin
Old Aug 15, 2004 | 01:30 PM
H2290's Avatar
Default Re: A/C Help for 90 EX Coupe (pothole0222)
Get a string or something and wrap it around every pulley you want to keep and tie it off at the correct length. Then go up to PepBoys or wherever with that string and the old belt and tell them you want that particular rib pattern from the old belt but in the length of the string. They will look at the pattern and measure the string and give you a belt. Took them about 2 minutes when I removed A/C and P/S from my H22.
Old Aug 15, 2004 | 08:56 PM
Sounds like a good idea, thanks for the input!
nigelnuggets
Nov 19, 2007 05:52 PM
hpsi93
Aug 26, 2007 02:47 AM
BBuncky2
Jan 10, 2006 11:48 AM
oxSLEEPERxo
Mar 20, 2005 11:23 AM
BlackGS-R
Aug 11, 2004 05:15 PM
