Differences between b-series heads.
Who is Mr Robot?
I need a b-series head to fab up a turbo manifold. Its going in a 99si. Now, i found a b18a1 head, is it really all that different from the b16a head in terms of port height and overall height? will it work to fab up the manifold and d/p?
Who is Mr Robot?
Thats not what i need to know, i just need to know if, externally, the two heads are the same on the exhaust side, im not running this head, its just for mock up.
You have a 99 si with the b16a2 motor/doch vtec. The b18a1 is the worst b-series head and it's not even a vtec head. The best stock head is the type r witch is the same head as the b16 but with different cams/internals. I would just keep you stock head and upgrade the internals if you really need it too.
Who is Mr Robot?
I'm not running the b18 head, it is strictly for manifold mock up and fabrication, it will spend its life sitting on a block on a motor stand. I happen to like vtec and will kill to keep it
DSLHONDA
Oct 30, 2004 09:57 AM
