ITB-Turbo motor :)
Old Aug 15, 2004 | 09:19 AM
Anthonyl469's Avatar
Default ITB-Turbo motor :)
So far I havent seen anyone on here try an Idividual Throttle Bodied Turbo motor...I think I will give it a shot...I have a set of 38 mm ITBs layin around and was thinkin about all this...does anyone know where I can purchase some aluminum pipe that could be welded as runners so I can weld on the ITBs to the pipe? I figure this is gonna be a pretty difficult setup but I will have help with hondata and such...I am gonna have to also make a sheetmetal box on the ITBs so the charged air is captured...if anyone has any experience with this please let me know because I figure I will be in for a few surprises
Old Aug 15, 2004 | 09:58 AM
Rick Solis's Avatar
Default Re: ITB-Turbo motor :) (Anthonyl469)
RB26DET
Old Aug 15, 2004 | 10:00 AM
Default Re: ITB-Turbo motor :) (Rick Solis)
TWM SR20DET...I know all this...Honduh tho
Old Aug 15, 2004 | 02:39 PM
egizzle8
Guest
Posts: n/a
Don't for the SR20DET from the RNN14(GTIR) also incorporated ITB's and FI.
Old Aug 15, 2004 | 04:43 PM
SpeedDreamz.com's Avatar
Default Re: ITB-Turbo motor :) (egizzle6)
It can be done pretty easily I guess. You are just up the street from us in Tuscaloosa.
Old Aug 15, 2004 | 04:53 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: ITB-Turbo motor :) (30psiCiv)
twm makes a plenum for it's itb's for guys that want to run a filter or a turbo, just thought you'd like to know
Old Aug 15, 2004 | 06:29 PM
egizzle8
Guest
Posts: n/a
Default Re: ITB-Turbo motor :) (wantboost)
I can't imagine it would be too hard to make a plenum and then it would solve all the vaccum problems with ITB. Only hard part would be to make the flange to match up with the ITB(I'm think of motorcycle ITB and not TWM's) and still make it clear the firewall. It would be cool to see. I have a set of cbr600's just sitting in my garage that I picked up to use for this idea but just never had the time or the resources to complete it.
Old Aug 16, 2004 | 10:10 AM
Aquafina's Avatar
Made a thread about this a long time ago when I didn't know wtf I was talking about.
Old Aug 16, 2004 | 02:46 PM
Doctor CorteZ's Avatar
bolt on plenum.
ITB's and boost would be ridiculous , so I added that to the list of winter projects
Old Aug 16, 2004 | 04:01 PM
Rick Solis's Avatar
Theres a reason the worlds fastest turbo Hondas run Intake manifolds...
Do some research on the RB26DET motor, they come with ITB's from the factory... There are several downsides to ITB's and boost on the RB26, thats the reason you see a large majority of the really fast Skylines running single TB plenums as apposed to ITB's...
Old Aug 16, 2004 | 06:22 PM
hurleyboarder21's Avatar
but there has to be some pro's for running itb's for FI... if it comes like that from the factory. please explain yourself to educate the rest of us becuase it would be interesting to know why a single tb is better than itbs for boost.
Old Aug 16, 2004 | 06:43 PM
FwdCivicHatch's Avatar
Default Re: ITB-Turbo motor :) (hurleyboarder21)
it doesn't come with enornous amounts of HP though either....
Old Aug 16, 2004 | 08:22 PM
non's Avatar
non
Default Re: ITB-Turbo motor :) (FwdCivicHatch)
the idivdual throttle plates severely restrict airflow since it's forced induction they only need to have big runers and it will be just as well without 4-6x the throttle plate turbulence
Old Aug 16, 2004 | 08:57 PM
eg_type_r93's Avatar
Default Re: ITB-Turbo motor :) (eg1R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg1R &raquo;</TD></TR><TR><TD CLASS="quote">the throttle plate turbulence</TD></TR></TABLE>
Old Aug 16, 2004 | 10:15 PM
Default Re: ITB-Turbo motor :) (eg_type_r93)
sweet, thanks for explaining it, that helps out a lot. now i know why the single tb is better than itb's for FI.
Old Aug 16, 2004 | 10:45 PM
C-Zero's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">twm makes a plenum for it's itb's for guys that want to run a filter or a turbo, just thought you'd like to know</TD></TR></TABLE>
Bullshit
http://www.twminduction.com/airbox.htm
NOTE: THESE UNITS CANNOT BE PRESSURIZED.
civic_driver
Aug 19, 2005 08:09 PM
tony n.
Jul 10, 2005 09:14 PM
Hatchorama
Jun 1, 2005 06:52 AM
trbcivic
Dec 2, 2003 11:32 PM
ezark
Jan 6, 2002 11:22 AM
