The engine in my car....
Old Aug 14, 2004 | 08:53 PM
Yeehaw's Avatar
Default The engine in my car....
Like Ive said before Im a mustang guy who bought a civic.
I kinda understand the Vtec thing but is my car a DOHC or a SOHC or does it change from SOHC to DOHC when I hit Vtec or am I horribly confused.
Also when does it engage? because i cannot really feel it or hear it.
BTW, 01 Civic EX 2 door.....
Old Aug 14, 2004 | 08:54 PM
hatchling37's Avatar
Default Re: The engine in my car.... (Yeehaw)
It's a 1.7L SOHC VTEC motor
Old Aug 14, 2004 | 08:55 PM
Yeehaw's Avatar
Default Re: The engine in my car.... (hatchling37)
Now which Hondas have the DOHC Vtec?
Old Aug 14, 2004 | 09:00 PM
H2290's Avatar
You're a bit confused. Check out http://auto.howstuffworks.com/question229.htm to learn about VTEC. Also, there are lots of DOHC engines. Most common ones mentioned with Civics: B16, B18, H22
Old Aug 14, 2004 | 09:02 PM
Yeehaw's Avatar
Default Re: The engine in my car.... (H2290)
Are the Bseries stock in certain civics?
Old Aug 14, 2004 | 09:03 PM
blackdelslo's Avatar
All of the B and H series are DOHC, If your planning on swapping, I wouldnt look at anything other than GSR, Type-R or H22A
Old Aug 14, 2004 | 09:07 PM
Default Re: The engine in my car.... (delLudeVTEC)
Whoa, not all of the B-series if you want to get technical. The 88-91 Prelude B20? was a B-series. You're looking into the "next gen" motor swaps. I think you would benefit greatly from search for the many K20 threads that have been started on here... (Shaun Hillian (sp?) as key word).
eL's Avatar
eL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yeehaw &raquo;</TD></TR><TR><TD CLASS="quote">Are the Bseries stock in certain civics?</TD></TR></TABLE>
The 1999-2000 Civic Si comes stock with a b16a2 which is a DOHC VTEC engine.
Old Aug 14, 2004 | 09:10 PM
ABK's Avatar
ABK
Default Re: The engine in my car.... (eL)
yeah K series too in 01 and up honda/acura line. Does anybody know what motor you can swap into a d17 powered civic? Because I was at my local shop and I've see a new d17 laying around swapped out for something else, just curious (I've heard it's even harder to put in a K series in that bitch then EG).
Old Aug 14, 2004 | 09:23 PM
WongFeihung's Avatar
Default Re: The engine in my car.... (ABK)
it is difficult to hear vtec kicking in, in a sohc vtec motor. By installing an intake, header, exahust, etc etc it becomes a bit more easy to hear vtec kick in. Sohc vtec is more for economical purposes.
Old Aug 14, 2004 | 09:25 PM
ABK's Avatar
ABK
Default Re: The engine in my car.... (WongFeihung)
you can't hear a vtec kick in on that car, it activates at like 2000 rpms lol, I think it's only a ignition change over, no cam change over because you won't have enough oil pressure at 2000 rpms to lock the rocker arms.
hypeonline
Apr 4, 2006 07:10 AM
LaOstha
25
Jun 22, 2005 11:56 PM
coupe99vtec
18
Feb 24, 2005 12:08 AM
crzyfool24
Nov 17, 2003 02:32 PM
RobertMcDonald
Aug 25, 2002 04:09 PM
