P28 OBD1 ECU - JDM or USDM?
Old Aug 14, 2004 | 12:27 PM
angela_itr's Avatar
Default P28 OBD1 ECU - JDM or USDM?
I just bought a P28 OBD1 ECU with OBD2 sockets for my UK ITR, which I need so I can run Hondata engine management. I'm getting a solid CEL and the car won't even fire up properly, let alone idle.
Someone has suggested it might be a JDM ECU, rather than a UK/US one - can anyone tell me how I can tell the difference, and whether this would cause a solid CEL?
Would the Hondata map be different for the two ECUs?
Old Aug 14, 2004 | 04:31 PM
DragII's Avatar
25 Year Member
Default Re: P28 OBD1 ECU - JDM or USDM? (angela_itr)
are you running a hondata map on it now, or did you just plug it in and go? it shouldn't matter what country it came from.
Old Aug 14, 2004 | 06:39 PM
dax-es's Avatar
Default Re: P28 OBD1 ECU - JDM or USDM? (.D2)
I've only had a solid CEL when there's a problem accessing the external ROM. ie - There isn't one installed, it's installed incorrectly, or the program loaded is corrupt.
s0ul
Sep 15, 2010 12:17 PM
Milab21
Mar 26, 2008 05:05 PM
angela_itr
Aug 14, 2004 01:11 PM
BringIT
Jan 26, 2004 08:46 AM
