Got any LSD?
Does anyone know if the final drive can be changed gears is what i mean like a 4.4 or 4.7 i think. sorry if this is outa the blue cuz i gots lsd on my B16a cable trans and i cant change the this? what companies offer some final drives that u guys know of thanx sorry for butting in
I don't think this is required but some aftermarket LSD's need to change the speed sensor learned that with Kaaz
but LSD has nothing to do with the gear ratio as far as I know....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid1990crx »</TD></TR><TR><TD CLASS="quote">Is the lsd y1 tranny worth the extra $300 from hmotors?</TD></TR></TABLE>
That's debatable, since it is a Y1. The LSD itself is worth it but I am not a fan of the Y1 trans for many reasons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Is there a noticeable difference with lsd and non-lsd?</TD></TR></TABLE>
Huge difference depending on what you do with the car. For autocross and circuit track, it is like a night and day difference. For daily driving and drag, the difference is not so noticeable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DployinCRX »</TD></TR><TR><TD CLASS="quote">Does anyone know if the final drive can be changed gears is what i mean like a 4.4 or 4.7 i think. sorry if this is outa the blue cuz i gots lsd on my B16a cable trans and i cant change the this? what companies offer some final drives that u guys know of thanx sorry for butting in
It depends on what transmission you have.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazie1 »</TD></TR><TR><TD CLASS="quote">but LSD has nothing to do with the gear ratio</TD></TR></TABLE>
Right. The differential does bolt to the ring gear of the final drive, but it has nothing to do with the gear ratios.
</TD></TR></TABLE>It depends on what transmission you have.
ive had alot of engine /tranny combinations, and my final setup would be.
any hydraulic lsd complete motor swap, with a hasport mount kit.
this way you get a newer motor , tranny, electronics, etc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">That's debatable, since it is a Y1. The LSD itself is worth it but I am not a fan of the Y1 trans for many reasons.</TD></TR></TABLE>
1st gear is very long to me. Also can't change the final gear either.
Either way I'm happy with my Y1.
[QUOTE=Targa250R]That's debatable, since it is a Y1. The LSD itself is worth it but I am not a fan of the Y1 trans for many reasons.
....just curious...what reasons??What tranny would u recomend...ys1,s1?
You cant rebuild a Y1 and 3rd gear syncros go bad very ofter on these trannies.
I have 90-91 LS tranny in my car(4.400 final drive and short gears) with a quaife. You would probably have around 1100 bucks in this setup and it will be way better than the OEM honda clutching LSD which works fine but does wear out, and doesnt repond as well as the Quaife. My car eats exotics and other hondas alike at autocrosses and hold it own on trackdays even with the underpowered but torquey Ls motor.
essex
Jul 9, 2008 08:37 PM
spettinger
Nov 1, 2002 03:27 AM
