Differnce between MIG and TIG-small writeup
Old Aug 14, 2004 | 09:40 AM
Anthonyl469's Avatar
Default Differnce between MIG and TIG-small writeup
Here is a small chop up of a wrtieup for the basics. What is the Differnece between TIG and MIG welding...
So here we go.
The TIG process lets you weld thinner material than other processes. If you want to solve problems related to burn-through or warping when Stick or wire welding, TIG might be the solution. TIG also provides excellent fusion. While it's hard to learn, takes a lot of skill and is slow, the quality of a TIG weld bead meets the needs of aerospace, power piping and other critical applications. TIG also produces the best looking weld beads, which is why it is often specified when cosmetic appearances really count — and why TIG welding operators are considered the artists of the welding world.
Here shows the gun, electrode, and rod...the rod is held in hand and melts to the metal which you are welding.
Here helps you actually realize why it welds...The "electricity" melts the filler rod (thing you hold in your hand that melts the metal together) to the metal you are working on.
MIG and flux cored welding offer advantages over other welding processes, especially for the novice. With these two processes, the welding machine creates an arc between the work piece (what you want to weld) and a continuously consumable electrode (the "wire" in these wire welding processes). The operator need only focus on directing the MIG gun at the joint and proper motion. Most welding machines that can MIG weld can also flux cored weld.
Here is the outlay of the gun... Understanding what all the parts are and what they do is very helpful.
Fluxed core welding as asked:
Your average solder has a cleaning agent in-usually Rosin core. The filler actually helps to clean the metal so the new metal can adhere to it. Flux cored welding takes on the same principal. Gas MIG uses an Argon gas mix to shield of atmospheric gases and create a clean weld. Instead of using gas, Fluxed core welding has a type of "solder-like Rosin core"...just not actual Rosin. Flux cored welding can get really hot and is not usually used on really thin metal do the the weld "burning through".
Here is your typcial MIG, you usually had a spot in the back to hook up gas, Gas is used to "purify" the weld and have differnt heat characteristics. Gas welds usually look better than non gas-flux cored welds.
Let me know guys about if this confuses you or something, I am only 17 years old...bare with me
Modified by Anthonyl469 at 10:32 PM 8/15/2004
Modified by Anthonyl469 at 10:33 PM 8/15/2004
Old Aug 14, 2004 | 11:18 AM
MonkeyManStunna's Avatar
Default Re: Differnce between MIG and TIG-small writeup (Anthonyl469)
nice write up man!
Sticky material!
Old Aug 14, 2004 | 12:15 PM
omar256hxc's Avatar
Default Re: Differnce between MIG and TIG-small writeup (ExcelcivicSi)
i taaught this boy very well
Old Aug 14, 2004 | 02:02 PM
Default Re: Differnce between MIG and TIG-small writeup (xhatchx)
if you wanna learn for real come over and i will gas up the Lincoln and put you on some metal
Old Aug 15, 2004 | 11:19 AM
RCautoworks's Avatar
Nice little write up, it seems like you did not touch a lot on flux core welds, care to explain a flux core weld a little more.
Old Aug 15, 2004 | 11:42 AM
Luserkid's Avatar
Default Re: Differnce between MIG and TIG-small writeup (90blackcrx)
This will help alot of people understand the difference. This should really stay at the top in red letters.
Edit: changed read to red.
Modified by Luserkid at 6:42 PM 8/15/2004
Old Aug 15, 2004 | 11:50 AM
DENCIO's Avatar
Default Re: Differnce between MIG and TIG-small writeup (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">This will help alot of people understand the difference. This should really stay at the top in read letters. </TD></TR></TABLE>
Old Aug 15, 2004 | 12:59 PM
eL's Avatar
eL
Taught me something... I was totally clueless about welding.
Old Aug 15, 2004 | 01:32 PM
Default Re: (eL)
a little on Flux now
Old Aug 15, 2004 | 01:41 PM
Default Re: (Anthonyl469)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Anthonyl469 &raquo;</TD></TR><TR><TD CLASS="quote">a little on Flux now</TD></TR></TABLE>
Thanks, just stopeed in, will read it all again later.
Old Aug 16, 2004 | 03:58 AM
vtec69's Avatar
Default Re: (90blackcrx)
nice write up
Old Aug 26, 2004 | 07:38 PM
91civicEX's Avatar
Default Re: (vtec69)
dont wanna start a new thread for this question so ill ask it here
any difference in strength between MIG and TIG welds? if i wanted to weld some mounts for an engine with a MIG welder would they hold? how skilled do i have to be? will some practice welds do the job?
Old Aug 26, 2004 | 09:53 PM
Cain Marko's Avatar
Rotary Lift Specialist
Default Re: (91civicLX)
im new with welding, but it seems that tig welding is somewhat like soldering(sp?), ive mig welded before, i sucked, but it takes practice, after awhile i got pretty good, and i made my girlfriend a table, it turned out rather sweet
Old Aug 27, 2004 | 09:54 AM
nonsense's Avatar
Default Re: (turtlecx92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtlecx92 &raquo;</TD></TR><TR><TD CLASS="quote">im new with welding, but it seems that tig welding is somewhat like soldering(sp?), ive mig welded before, i sucked, but it takes practice, after awhile i got pretty good, and i made my girlfriend a table, it turned out rather sweet</TD></TR></TABLE>
TIG is not really like soldering at all. Oxy-Ac is kinda like soldering. MIG and TIG both use gas to sheild. MIG's filler wire come out of the gun and causes the arc and is used as filler. TIG uses a tungsten (the T in TIG) electrode to creat the arc and you feed the filler in with the other hand.
MIG and TIG are both very strong, but there must be a reason that most racing associations only allow TIGed welds on your roll cage.
Old Aug 28, 2004 | 12:25 AM
EJ2-Fluffy's Avatar
Good write up for a 17 year old. Taught me a thing or two about welding
-Jon
Old Aug 28, 2004 | 05:01 AM
ExploitedRacing-HR's Avatar
[QUOTE=Anthonyl469] the filler rod (thing you hold in your hand that melts the metal together)QUOTE]
Not always true: Filler rod is not needed to melt the metals together, it simply aids the welder by filling in gaps and increasing weld strength. The Tig torch arc creates enough heat to melt surrounding metal and can be bonded togethed without filler rod if there a small enough gap between two work-peices being welded.
Old Aug 28, 2004 | 05:04 AM
I been owned by html.. once agian.
Welding / Fabrication
Mar 30, 2012 08:45 AM
AssItch1
24
Jul 24, 2009 04:56 PM
Touge Tuning
15
Feb 15, 2006 11:19 AM
gawath
11
Sep 23, 2005 07:36 AM
