tps problem
Old Aug 13, 2004 | 03:57 PM
kaj's Avatar
kaj
Default tps problem
my car used to idle at 500rpm no matter WHAT i did. even if i took out the idle adjust screw with or without the IACV plugged in. nothing worked.
pulled off TPS.. looked okay. put it back on, now car idles at 2000rpm with idle adjust screw all the way in.. and i have the CEL for "TPS angle blah, blah"
can someone tell me why i can't seem to get it right? if i turn the TPS, it revs higher. right now it's turned as far as it will go to get idle down. idle adjust screw is in all the way.
i'm lost. i know it has to do with voltage... but how do i FIX IT?? thanks!
Old Aug 14, 2004 | 03:34 PM
kaj's Avatar
kaj
Default Re: tps problem (kaj)
bump
Old Aug 14, 2004 | 05:05 PM
Xsi's Avatar
Xsi
http://www.integra.orcon.net.nz/tps
Old Aug 15, 2004 | 08:33 AM
kaj's Avatar
kaj
Default Re: (Xsi)
i tried that. it is adjusted all the way back. if i manually turn the throttle body, it will close a bit more and the idle will go down. almost as if my throttle cable is too tight, but it's not. so i'm thinking maybe i just need to back out the throttle stop set screw? i'll keep messing with it.
just seems weird to me how it is idling at 500rpm one minute, then 2000rpm then next.
Old Aug 15, 2004 | 08:43 AM
Sliced Beard's Avatar
Default Re: (kaj)
your TPS needs to be set at a certain voltage
and if in fact your TPS is bad I have one siting beside me that i will sell you
Old Aug 18, 2004 | 04:13 PM
kaj's Avatar
kaj
Default Re: (dirtyd463)
stupid, stupid mistake:
the lever on the TPS was OUTSIDE the space in the throttle body it was supposed to set in.
okay. all fixed. back to .45 volts!!!
but i STILL have no idea why my car idles the same no matter what i adjust. it's at 750 rpm no matter HOW far the idle adjust screw is out, timing, etc, etc. i think the uberdata chip is programmed for 750rpm
Old Aug 18, 2004 | 05:03 PM
Default Re: (kaj)
if it automatically idles at 750 that is because the ecu is programmed to idle there
call me Cap'n Obvious
Old Aug 18, 2004 | 05:55 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote">if it automatically idles at 750 that is because the ecu is programmed to idle there
call me Cap'n Obvious</TD></TR></TABLE>
well thank you captain obvious
Old Aug 26, 2004 | 05:51 PM
kaj's Avatar
kaj
Default Re: (DirtySol)
actually, it is programmed to idle @ 1000 rpm via Uberdata, Capt Obvious.
i assume the car idles low now because the base map i'm using is too rich. REALLY rich.
Old Aug 27, 2004 | 09:11 AM
Default Re: (kaj)
possible
Old Aug 30, 2004 | 07:25 PM
kaj's Avatar
kaj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtySol &raquo;</TD></TR><TR><TD CLASS="quote">possible </TD></TR></TABLE>
did some checking. TPS is fine. car is running SO rich, it doesn't register on wideband below 3500rpm and more than 10hg/in of vaccum !!!!
i'm not driving it 'till it's tuned. washing your cylinders is a bad thing.
Old Aug 30, 2004 | 07:32 PM
Antilag's Avatar
Default Re: (kaj)
what size injectors? What is your injector opening time set at (ms)? Can you datalog?
Old Sep 1, 2004 | 04:37 PM
kaj's Avatar
kaj
Default Re: (9sech22civic)
well, i'm running a map meant for a JRSC. it was just to get my car tuned, which i did. the injectors were 550s and the map was just set for waaaaay more fuel @ 11+hg vaccum and less than 4k rpm than it needed. really bad. all is well now, though. car runs great. i love being tuned and happy
itzyaboyzeem03
Sep 30, 2009 04:11 PM
b_serious
Feb 8, 2006 05:42 PM
madcrossover
Jul 2, 2005 10:18 AM
BDogggUT34
Jan 18, 2005 04:05 PM
oi-punx
Nov 14, 2002 02:01 PM
