ECU codes 3,17,21,23 please help
Old Aug 13, 2004 | 02:13 PM
illestrolla247's Avatar
Default ECU codes 3,17,21,23 please help
so im throwing codes like i said they are the map sensor , Vss , vtec spool solenoid, and knock sensor, the knock one sounds pretty not cool
any idea what exactly all of these mean?
Old Aug 13, 2004 | 02:21 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: ECU codes 3,17,21,23 please help (illestrolla247)
3 is your MAP sensor electrical problem and 17 is the VSS or car speed sensor.
dont hold me responsalbe cause i dont have these codes, but I think 21 is your VETC solonoid and 23 is the VTEC oil presure sensor.
Old Aug 13, 2004 | 02:28 PM
Default Re: ECU codes 3,17,21,23 please help (JC18)
21 is the vtec spool solenoid valve and 23 is the one im worreid about its the knock sensor and im not sure what that is
Old Aug 13, 2004 | 02:32 PM
DieMaster's Avatar
look at my avatar <--- that's waht i'm doing now! i didnt see u knew what the codes were.
The knock sensor is on the back of the head and detects things like detonation, preignition, and other harmfull-things-to-the-engine symtoms.
Old Aug 13, 2004 | 02:46 PM
my car is turboed so this is why it scares me
if one of those many things occured once or twice would the code still be on the ecu or will it clear off?
Old Aug 13, 2004 | 06:48 PM
DieMaster's Avatar
Getting the code means that there's a problem with the sensor, not that your getting detonation,etc.., check for bad grounds or lose conections.
is your car a OBD0 or 1? i need to know for your last question
Old Aug 13, 2004 | 06:52 PM
DieMaster's Avatar
this is what the knock sensor looks like. on the fierwall side of the head(rear) just below the intake manafold.
brcivic411
17
Aug 26, 2011 01:15 PM
b18cEF9
Dec 20, 2004 04:22 PM
birds_sol_94
Aug 19, 2004 04:23 PM
smslude
Jan 14, 2003 10:37 PM
justinlude
Jan 31, 2002 12:17 PM
