hg gone bad!
Old Aug 13, 2004 | 09:44 AM
slowricer's Avatar
Default hg gone bad!
myth or a fact??
do synthetic oil causes blown head gasket??? don't know the basis, i just heard about so don't ask me why it would.
and another thing, i had may HG fixed not even a yr ago. now i have another blown head gasket.. poor installation or is this a recurring problem for honda civics??
any input will be great .. educate me pls....
Old Aug 13, 2004 | 09:48 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Default Re: hg gone bad! (slowricer)
No, synthetic oil does not cause blown head gaskets. Class dismissed.
Just curious, what was the reasoning you heard behind this myth?
Old Aug 13, 2004 | 02:12 PM
slowricer's Avatar
Default Re: hg gone bad! (tjbizzo)
as i've posted up, don't know the reason or any basis of it...
i was using synthetic oil on my 94 civic lx then i had a blown head gasket.
got it fixed and now less than a yr after same problem..
what went wrong installation mishap or recurring problem???
Old Aug 13, 2004 | 06:24 PM
b16supertuner's Avatar
does the car get too hot? overheating will cause hg failure
Old Aug 13, 2004 | 06:25 PM
other things can attribute to HG failure such as improperly tourqed head bolts, dirty mating surfaces, etc.
Old Aug 13, 2004 | 07:27 PM
slowricer's Avatar
Default Re: hg gone bad! (b16supertuner)
well, the car overheats because of the blown hg...
Old Aug 13, 2004 | 08:07 PM
Malgerus's Avatar
Could be that the headbolts were reused... you're generally supposed to replace OEM headbolts, but who knows. I would have to guess at improperly cleaned gasket mating surfaces. That or the head is warped.
Old Aug 13, 2004 | 09:57 PM
IVI's Avatar
IVI
what are the exact symptoms your having?
just that the car overheats?
is there alot of white smoke coming out of the exhaust?
is your oil contaminated with coolant?
is your coolant contaminated with oil?
how long does it take for your car to overheat?
Old Aug 13, 2004 | 10:37 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowricer &raquo;</TD></TR><TR><TD CLASS="quote">as i've posted up, don't know the reason or any basis of it...
what went wrong installation mishap or recurring problem???</TD></TR></TABLE>
no synthetic doesnt blow your headgasket lol
ive got a huntch its one of a couple things
1) whoever redid the headgasket reused the head bolts
2) whoever redid the headgasket made a mistake (like torque order or spec)
3) you drive like a retard.
hate to be so blunt, but 2 headgaskets in a year isnt usually a car/engine problem. its a driver/technician problem.
Old Aug 13, 2004 | 10:56 PM
spaceman's Avatar
Default Re: hg gone bad! (Kamin)
lol..yeah dood what kamin said,also what kind of gasket are you using?
Old Aug 14, 2004 | 08:30 AM
slowricer's Avatar
Default Re: hg gone bad! (IVI)
no other symptoms besides overheating and coolant evaporating quickly ... after driving 30miles or so... but that was it...coolant is not contaminated with oil or vise versa...
oem head gasket is what the guy told me he used....
Old Aug 14, 2004 | 08:34 AM
slowricer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">no synthetic doesnt blow your headgasket lol
hate to be so blunt, but 2 headgaskets in a year isnt usually a car/engine problem. its a driver/technician problem. </TD></TR></TABLE>
good ideas ... kamin.. but i think i like number 3 the best....lol
how much do you guys think i will spend to get my hg replaced??
and hopefully done right this time......
Cameronphelan
Honda Civic (2001 - 2005)
May 29, 2015 10:23 AM
01_civic
Classic Hondas
Jun 3, 2012 06:58 PM
fourdoorteg
Jan 21, 2010 07:15 PM
livinlow
Nov 27, 2005 11:54 PM
Trellis
Sep 18, 2004 07:58 PM
