what axles do i need?
Old Aug 13, 2004 | 06:53 AM
anotheredhatch's Avatar
Default what axles do i need?
i have a 91 crx hf and need to know what axles to use. the engine is an ls b18 block with gsr head and tranny.
Old Aug 13, 2004 | 08:24 AM
kid-honda's Avatar
Default Re: what axles do i need? (anotheredhatch)
As said my stormin matt
Unaltered 1990-1993 Integra axles are NOT a perfect fit. First of all, the dust seals on the knuckles need to be removed. And then there is the possibility that the passenger side axle will be too long. If you just want a quick and easy axle to use, you can try a 1990-1993 Integra axle. Or you can use the RIGHT axles. And that would be either JDM SIR axles or their home made version (1990-1993 Integra inners with 1986-1989 Integra outers and shafts). A 1990-1993 Integra intermediate shaft should be used regardless.
Old Aug 19, 2004 | 06:11 AM
Sliced Beard's Avatar
Default Re: what axles do i need? (kid-honda)
hey greg...I have seen many many people use 90-93 teg axles WITHOUT any problems what so ever.....just remove the little rubber dust shields on the outer end and you will be just fine
Lsvteced6
Mar 11, 2018 08:14 AM
Gonzob16
Nov 23, 2006 08:19 AM
B20 BEAST
Apr 30, 2003 05:12 AM
ITR632
Apr 21, 2003 12:09 PM
joey1320
Dec 17, 2002 04:20 PM
