garrett t3/60-1 turbo ?
Old Aug 13, 2004 | 05:16 AM
B18C1CYA's Avatar
Default garrett t3/60-1 turbo ?
i wanted to know from some of you that use this turbo what you think of it and which you would recomend for my setup i have a fully built gsr and i have the fueling for 500hp no problem, but i wanted to know if the .63 stage 3 would be the one to get or get the .82 ? thanks in advance
Old Aug 13, 2004 | 12:51 PM
TheShodan's Avatar
Moderator
Default Re: garrett t3/60-1 turbo ? (B18C1CYA)
It's not bad, though for a little better spool the GT35E or SC61 would do much better. i've had both, but I've switch to TOUGE and road racing, so I went with the GT3037.
If you have a little extra cash, the GT35R (GT3040) would be the best for that GSR setup. Just finished a GSR which made over 526whp on 23psi. It was wonderful, and power-on-boost was not bad at all. PM me, I've got a spare one.
Old Aug 13, 2004 | 07:00 PM
V-SPEC 1's Avatar
I have that turbo w/ .82 a/r fully built LS/Vtec and made 540whp and 400 lbs. trq. @ 25 psi.
Old Aug 13, 2004 | 08:25 PM
dunkd's Avatar
i have the .63 and will be cranking to boost when my motor is broken in... hopefully it will handle 400 no problem
maximedx
Sep 24, 2006 12:59 PM
2LiterTurboSeR
Jun 6, 2005 09:08 PM
GsRHatchy1320
Aug 28, 2004 09:55 AM
b18bturbo
May 10, 2004 07:02 PM
