motor vibrates like crazy
Old Aug 12, 2004 | 12:44 PM
gsr2jdm's Avatar
Default motor vibrates like crazy
lifted car up and put in 1st gear and looks like the axels push the motor left to right
also makes clunk noise and vibrates when driving
thanks
Old Aug 12, 2004 | 12:55 PM
Filthy Focker!'s Avatar
Default Re: motor vibrates like crazy (gsr2jdm)
When you say first gear, i suspect it is manual?
When you let go of the clutch and step on the gas, does your shifter move?
fs
Old Aug 12, 2004 | 01:09 PM
SuzukaBlueAP2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr2jdm &raquo;</TD></TR><TR><TD CLASS="quote">lifted car up and put in 1st gear and looks like the axels push the motor left to right
thanks</TD></TR></TABLE>
A clunk when driving straight? Or when turning?
Old Aug 12, 2004 | 07:39 PM
gsr2jdm's Avatar
Default Re: motor vibrates like crazy (ScreaminTeg)
driving straight but its gone now drives normal which kind of upsets me but i'm gonna go out and replace those cv boots and tranny fluid
Old Aug 12, 2004 | 08:44 PM
3.504's Avatar
if the motors movin, i'd look at mounts. axles will shake under acceleration in a strait line if the inner joint is going, they'll click or pop when turning (usually w/ the wheel turned quite a bit) if the outter joints are going, but they dont do it bad enough to shake the motor when the wheels are in the air. check out all the mounts.
san_diego_DC
Jun 28, 2008 09:11 AM
russianswty
Jul 6, 2007 10:33 AM
xxmastermindxx
Nov 23, 2006 01:55 PM
redrelease
10
Aug 15, 2006 05:40 PM
DA jeshy
Mar 6, 2006 12:06 PM
