wheel size
Old Aug 12, 2004 | 11:55 AM
foolintherain617's Avatar
Default wheel size
Im not sure what forum to put this in but seeing as i have an integra i thought id put it here. My 90 GS has the stock 14" wheels with fairly new tires. Can i only get a 14" wheel for the tires or can i get a 15" or even a 16" on them? Id rather ask here than go to the store and be talked into buying all new wheels and tires if the wheels i want will fit the tires i have. Also, will a larger wheel size improve handling or ride quality?
Old Aug 12, 2004 | 12:07 PM
purplegsr's Avatar
Default Re: wheel size (foolintherain617)
um, what? You cannot get 15 inch wheels and put 14 inch tires on them. If you get bigger (15 or 16 in) wheels, you will need to buy an equally larger diameter tire as well. For example, someone with a 94 Integra GSR will have 15 inch wheels with 195/55 r15 tires. If they get 16 inch wheels, they should get 205/45 r16 tires or something close to those specs.
Old Aug 12, 2004 | 12:11 PM
ok. Just thought that maybe they could be strecthed by lowering air pressure or something. Im too cheap for new tires and wheels so it looks like ill be getting 14s
Old Aug 12, 2004 | 01:22 PM
Dc2 Powered's Avatar
too cheap?
i forgot the page but this page sells
yoko Avs es100 15in for liek 60 bucks each. thats not much at all.. someones gotta know the page
Old Aug 12, 2004 | 01:26 PM
-DKap-'s Avatar
Default Re: (Dc2 Powered)
https://honda-tech.com/zerothread?id=955409 this? seems like a great deal check it out ... and try to talk to him somewhere or get some1 to post for u or wait
Romo Pyro
Nov 5, 2009 02:49 PM
bigdaddyjimmyjam
Aug 8, 2006 06:49 PM
PatiKTP
Dec 13, 2002 11:45 AM
