how to clean engine /intake manifold?
Old Aug 12, 2004 | 09:27 AM
djsire's Avatar
Default how to clean engine /intake manifold?
i was adjusting my throttle cable and took off my intake. i noticed that my tb and im were completely engulfed in a thick layer of "black tar substance"i tried wiping it off with a screw driver wrapped in a old shirt, but hteres just so much of it and i cant reach the back. its also prolly in the runners ect. how doyou clean this. is there a solution that i can use? i heard about sea foam but dont know what it does or how to use it or where to get it
please help
ty
Old Aug 12, 2004 | 09:37 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: how to clean engine /intake manifold? (djsire)
Here is a how-to I found on Sea Foam. Just run a search on "sea foam" in the archives and you'll get a bunch of results from that. Thats where I found this at.
http://www.diyimports.com/seafoam.html
Old Aug 12, 2004 | 09:38 AM
hatchling37's Avatar
Old Aug 12, 2004 | 11:16 AM
Matty.'s Avatar
SIMPLE GREEN
Old Aug 12, 2004 | 11:18 AM
Deemeetree's Avatar
Electrician
Default Re: how to clean engine /intake manifold? (gumtape_deathmatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gumtape_deathmatch &raquo;</TD></TR><TR><TD CLASS="quote">SIMPLE GREEN</TD></TR></TABLE>
I'm not sure you want to use Simple Green inside the throttle body and intake manifold. I'd use that just to clean the OUTSIDE of the motor and firewall.
Old Aug 12, 2004 | 11:19 AM
Revolver's Avatar
Default Re: how to clean engine /intake manifold? (Dimi)
Sea Foam is some of the best sh*t on Earth.
Old Aug 12, 2004 | 11:26 AM
dohcdelsol93's Avatar
Sea Foam I sell tons of it. Will take the color off of your pants and varnish off of your engine parts
Old Aug 12, 2004 | 11:45 AM
djsire's Avatar
Default Re: how to clean engine /intake manifold? (dohcdelsol93)
ok i just got off the phone with the guy at napa in the bronx. he said they dont carry it then hung up on me. where can i get this stufff at.
Old Aug 12, 2004 | 11:48 AM
Revolver's Avatar
You should be able to get it at any NAPA, discount auto, autozone etc.
Old Aug 12, 2004 | 12:06 PM
jbs's Avatar
jbs
For the TB, you can also you carb or fuel injector cleaner. Just spray and wipe off.
Old Aug 12, 2004 | 12:30 PM
jessemarCc's Avatar
Default Re: (jbs)
Sea Foams the ****
Old Aug 12, 2004 | 12:34 PM
j0nptw's Avatar
Default Re: (bluracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluracer &raquo;</TD></TR><TR><TD CLASS="quote">Sea Foams the **** </TD></TR></TABLE>
Old Aug 12, 2004 | 12:54 PM
djsire's Avatar
Default Re: (j0nptw)
well how do you get up in the manifold. i tried using longer sticks with a old shirt tied to it but that didint work out to well
Old Aug 13, 2004 | 04:06 AM
H-T Order of Merit
Default Re:
quick question.
When you use Sea Foam and it "flushes" all the carbon build up and that out of the exhaust, is there a risk of that stuff getting stuck in the cat and clogging it? I just put a new cat and cat-back exhaust on my car and I don't want to mess it up with all this carbon build up going through it. Sorry if this is a stupid question. TIA
oh, I went to autzone and they didn't have it. I'll have to try NAPA and other car parts stores today.
Old Aug 13, 2004 | 08:24 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: Re: (TouringAccord)
there's always carb cleaner.
Old Aug 13, 2004 | 11:44 AM
djsire's Avatar
Default Re: Re: (vtecb20coupe)
ummm its efi so there is no carb.
also they do carry it at auto zone i just went and got some ask them for part number sf16 i also found that they make a transmission tune liquid. its number is tt16. has any one ever used the tranny tune?
Old Aug 13, 2004 | 11:55 AM
Deemeetree's Avatar
Electrician
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">quick question.
oh, I went to autzone and they didn't have it. I'll have to try NAPA and other car parts stores today.</TD></TR></TABLE>
It shouldn't clog it. It'll break it up into tiny pieces and maybe burn up. They'll probably get so small it'll blow right out of the exhuast system.
BTW, Pep Boys, AutoZone nor Oreilys has it. Only place I found it at was Advance Auto Parts.
Old Aug 13, 2004 | 11:59 AM
Soccerking3000's Avatar
Default Re: Re: (djsire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire &raquo;</TD></TR><TR><TD CLASS="quote">ummm its efi so there is no carb.
also they do carry it at auto zone i just went and got some ask them for part number sf16 i also found that they make a transmission tune liquid. its number is tt16. has any one ever used the tranny tune?</TD></TR></TABLE>
alot of people use carb cleaner to clean parts of their cars off, it has nohing to do with the car being efi, ya i picked some up and seafoam is the best stuff period
Old Aug 13, 2004 | 12:03 PM
FF DRFT's Avatar
Default Re: Re: (Soccerking3000)
I used to work at Advance. All of their stores carry it.
Old Aug 13, 2004 | 12:09 PM
alotawatts's Avatar
Is'nt there Thottle Body Cleaner available ? Regular Carb cleaner and Sea Foam can F*ck up sensors, plastic parts etc.
Old Aug 16, 2004 | 03:11 AM
H-T Order of Merit
Default Re: Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">
BTW, Pep Boys, AutoZone nor Oreilys has it. Only place I found it at was Advance Auto Parts.</TD></TR></TABLE>
ok, sounds good, thanks for the reply. I just don't want to clean one thing and clog another. I'll be getting rid of the motor anyway, just want to keep it running smooth, but I'll be keeping the exhaust the way it is.
I went to NAPA and they carry it but were all out. I'll either try Advance Auto Parts or just wait until NAPA gets them back in stock.
Old Aug 17, 2004 | 09:51 AM
djsire's Avatar
ok i dont know what happended. i did the sea foam through the brake booster
. and i put some in gas tank. i also used tranny tune made by the same people.
while im driving about an hour later. my car gets really loud(like when my exhaust fell off) and it has been that way scince. does anyone konw what could have happened. i suspect the cat converter went "dead" or something. but my car sounds like ****. has alot more pep though.
Old Aug 17, 2004 | 10:54 AM
5w20's Avatar
Beware of your catalyst.
Old Aug 17, 2004 | 10:56 AM
Malakai's Avatar
u could just use WD-40. always workd for me
Old Aug 17, 2004 | 12:12 PM
djsire's Avatar
Default Re: (Malakai)
does anyone know what it could be. will a cat get clogged or blown through by the sea foam
