AEBS and PCV valve?
Hey guys can you please post some pics of how you ran your PCV valve with you AEBS IM? I am not following how you can redirrect the hose to the back of the IM and still keep the Vapors flowing up?
Thanks in advance
oh and YES I did search and found nothing!
Thanks in advance
I had the same problem .. I don't know if this is the correct solution but I bought 24" of vacuum line and ran it from the PCV to one of the nipples in the rear of the AEBS.. There's probably a more elegant way of doing this but I was little short on time... Here is a pic .. not the best pic for this illustration but I hope it helps ..
Remove the PCV hose A and nipple that goes from the oil separator box to PCV valve. Place the PCV valve into the grommet on top of the oil separator box. Then route the 3/8" hose underneath and to the back of the AEBS manifold.
The PCV pathway does not need any sort of up or down flowing orientation to work properly. The flow is pressure differential driven by the vacuum naturally created by the engine pumping.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC »</TD></TR><TR><TD CLASS="quote">Remove the PCV hose A and nipple that goes from the oil separator box to PCV valve. Place the PCV valve into the grommet on top of the oil separator box. Then route the 3/8" hose underneath and to the back of the AEBS manifold.</TD></TR></TABLE>
This is EXACTLY what I was thinking when I said there was a more elegant way to do this
vietnamese0utlawz
May 19, 2006 09:46 PM
racinskittle
Sep 26, 2003 02:35 AM
