what is this gray plug? please help!
ok i have a gray plug located just behind my intake manifold that has 2 wires on it:
-one wire is red (no volt detected)
-and the other one is yellow with black stripe (tested 12.58v)
the plug would click into the "knock sensor" housing perfectly, but i know it isn't for the knock sensor because knock sensors have ONLY 1 wire to it.
any ideas?
any ideas?
Afte checking my manual it could be either one but i can only match up one side of the circuit to something i cant find a plain red wire on either component so good luck man!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trav »</TD></TR><TR><TD CLASS="quote">i think its the AIR Intake Sensor. like noc said.</TD></TR></TABLE>
hmm but my iat sensor and iacv sensors are all working...no codes for them...except code 23 (knock sensor).
This is for an EG with stock engine and wiring?
If so, this is most likely for the purge cut-off/control solenoid valve. The connector for this solenoid valve has a red wire and a yellow/black wire in a two prong connector.
On most D/B series motors, this valve mounts on the back of the intake manifold, to the driver side of the vacuum fitting for the brake booster.
Yellow/black is +12V switched by the main relay and red is controlled by ECU. You should measure positive voltage from the yellow/black to the red wire while the engine is warmed up and idling, but there will not necessary be voltage from the red wire to ground.
Here is the schematic (solenoid is circled)
Here is where it comes out of the harness (117 - circled)
Hopefully that helps you out........
Mike
Modified by mrmunsell at 11:30 PM 8/11/2004
Modified by mrmunsell at 11:31 PM 8/11/2004
Mike
Where the hell did you get this great illistration/schematic at, did you get it from the helms manaul if so it's not in mine
sorry for the off topic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civtegra_hybrid »</TD></TR><TR><TD CLASS="quote">on what side is in on??? it mite be the ITM check the codes</TD></TR></TABLE>
the gray plug came out of the wire harness and the harness is not the original harness on my 93 civic ex 4dr. it was an obd1 harness i bought from "2litreLsVtec" and guaranteed to work.
about the codes, i'm only getting code 23 (knock sensor), even after resetting ecu. that gray plug is a mystery....
I just checked the wiring diagram for the Integra as well... and the only plug under the hood I see with those two wires colors is again the purge cut-off solenoid valve. So whether this harness is an OBD-I civic or teg harness, that connector you describe should go to this solenoid valve.
Did you check that yet? It's usually on the back of the manifold, to the driver side of the vacuum connection to the brake booster. If something is already connected to the solenoid valve, check the wire color(s)... maybe the wrong connector is there now (like the knock sensor connector, etc).
Mike
Mike
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrmunsell »</TD></TR><TR><TD CLASS="quote">I just checked the wiring diagram for the Integra as well... and the only plug under the hood I see with those two wires colors is again the purge cut-off solenoid valve. So whether this harness is an OBD-I civic or teg harness, that connector you describe should go to this solenoid valve.
Mike</TD></TR></TABLE>
if the purge cut-off solenoid valve is not plugged in with the right wires, would it throw a code? i'm not getting any other code than the code 23 "knock sensor".
beginmyhonda
Jul 29, 2009 02:14 PM
E.Honda
21
Dec 14, 2005 03:59 AM
