Will a d15b8 (1992 cx) distributor work on a 1996 d15b?
Old Aug 11, 2004 | 08:45 PM
eastbay92cx's Avatar
Default Will a d15b8 (1992 cx) distributor work on a 1996 d15b?
Looking to use the fuel rail, injectors, and distributor from my cx on this 1996 sohc vtec motor. Also, since this motor is odb 2, I'll have an extra plug in the back of the block, a knock sensor, right? What should I do, leave this in with the wire cut / capped off, a p28 ecu shouldn't show a cel with this motor hooked up with everything functioning, right? Thanks..
Old Aug 12, 2004 | 02:38 AM
Fobtions's Avatar
Default Re: Will a d15b8 (1992 cx) distributor work on a 1996 d15b? (eastbay92cx)
it should bolt up just fine.
CivicFTW
Jul 9, 2010 07:59 AM
Tad
Jun 27, 2004 11:01 AM
92CIVICCX
Aug 16, 2002 11:27 PM
