A Mutt DOHC Vtec???
Im building a motor for my 95 coupe. Im trying to do this cheap so i am kinda piecing the parts together from all over the place. I have a B16a block(si) and a LS head with GSR cams. If i get a vtec selonoid will the head be just like a GSR??? Is this decision good to mate a GSR head with an SI block??? What can i expect from this mess????
to make an LS head vtec, you're going to need to sell that head and buy a vtec one
and no your gsr cams are not worthless, they just don't work on that head, i think (definatly not vtec at least LOLOL). you can always sell them to help save up for a vtec head, or some nice cams for your LS head
yes I believe GSR cams will fit in a B16 head, but there will be timing issues,
BUMP for the correct answer, I'm like 99% sure on that tho
but why were you going to put a non-vtec head(LS) in place of your B16 (vtec) head?
It is normally the EXACT opposite lol
A couple of things:
-You can't change a non Vtec head, into a Vtec head.
-A Vtec cam will not fit in a non-Vtec head, and the other way around.
-You can put the GSR cams in the B16 head w/out any issues. It's not worth it IMO, but it fits right in.
If you're looking for advice, I'd say save some more money, do a little more research, and you'll be on your way. HT is an excellent learning resource with pages, and pages of useful info. I personally have a "mutt" engine myself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaoss_11 »</TD></TR><TR><TD CLASS="quote">Why not put gsr cams in a b16 head? If he has them why not?</TD></TR></TABLE>
There's nothing wrong with putting them in there, but I wouldn't waste my time. I've never seen dyno results, or felt any positive results from doing it. Unless you have an automatic B16 head, I'd just leave the stockers, or save up a couple hundred bucks for an ITR cam if I was keeping it low budget.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaoss_11 »</TD></TR><TR><TD CLASS="quote">Well thats true but from my point of view every bit helps and counts.</TD></TR></TABLE>
Agreed.
But thats the problem, I've never seen any positive results from that swap. I've driven a few "before and after" set ups, and felt no difference at all, and the dyno showed no difference either.
Agreed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicVX94 »</TD></TR><TR><TD CLASS="quote">to make an LS head vtec, you're going to need to sell that head and buy a vtec one and no your gsr cams are not worthless, they just don't work on that head, i think (definatly not vtec at least LOLOL). you can always sell them to help save up for a vtec head, or some nice cams for your LS head</TD></TR></TABLE>
Muuurph
17
Sep 26, 2008 01:37 PM
