SRS Codes
My SRS light came on in the winter sometime, and didnt feel like taking it to honda since they charge 60$ an hour. Anyways, my CEL light came on today, and I tested it by doing this:
"On the passenger side of your car, under the dash beneath the glove box, you will find a green cover above the kickpanel that houses a blue connector that has two wires.
All that you need to do is turn the ignition off, and using the piece of wire or paperclip, jump the blue connector so that you connect the two wires together. Basically stick one end of the paperclip or peice of wire into one prong on the connector and stick the other end of the paperclip or wire into the other prong.
Once you have done this, turn the key to the IGN position and watch your CEL light. It will illuminate in a series of flashes. "
When I did that, the SRS light did some codes to, and I dont know if they wokr the same as the CEL, but it flashed the numbers 72, 73 and then 72 again. Does anyone know what this means? thanks
Ricky Equihua
Nov 2, 2013 09:00 AM
baonest1
Mar 13, 2003 07:26 PM
