Converting obd2 motor to obd1
I have a 92 vx hatch getting a obd2 vtec motor - I want to use the civics wiring harness w/ a p30. What will I need to change on the motor... dizzy? injectors? alternator? is that all? is there a way to rewire them or do I have to buy obd1 stuff? any help would be appreciated.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo9Nut »</TD></TR><TR><TD CLASS="quote">JDM engine don't have OBDII like the USDM. They only have what equivalent to OBDI here in the US.</TD></TR></TABLE>
what? so steve was wrong when he said he gave my friend an OBD2 B18C-R engine???? i couldda swore they made obd2 in japan dude...
You are wrong. They not the same as USDM (JDM kinda stay with OBD2a style ECU), not OBD1 style.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eggie75 »</TD></TR><TR><TD CLASS="quote">dizzy?</TD></TR></TABLE>
All you have to do is repin it. It is the Same dizzy as OBD1, but the plugs are different.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eggie75 »</TD></TR><TR><TD CLASS="quote">injectors?</TD></TR></TABLE>
you have to change the injector clips. They are as same as OBD1, but the clips are different.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eggie75 »</TD></TR><TR><TD CLASS="quote">alternator?</TD></TR></TABLE>
Yes, OBD2 has a different plug then OBD1. You can either: rewire it, or buy a OBD1 alt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eggie75 »</TD></TR><TR><TD CLASS="quote"> is that all?</TD></TR></TABLE>
You have a VX so you have to do the "VX fix". That means you have to change your 5 wire o2 to a 4 wire o2. You will find the "how to" in the big H22a at the top of this forum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eggie75 »</TD></TR><TR><TD CLASS="quote">is there a way to rewire them or do I have to buy obd1 stuff?</TD></TR></TABLE>
If you do not want to rewire them, buy a 96+ integra harness (GSR being the less wiring). It will plug into your civic harness and you will only have to run wires from the shock tower to the ECU (knock).
Plus, a P30 is not the best for a ITR motor. You should get a: chipped P28 or a p72.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eggie75 »</TD></TR><TR><TD CLASS="quote"> isn't p28 sohc?</TD></TR></TABLE>
You would be correct. You chip it with better fuel and ignition maps to better proform (more HP) for your engine.
Yes, the p72 is a dual runner, but you could chip either one for better performance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eggie75 »</TD></TR><TR><TD CLASS="quote">how about chipping the p30?</TD></TR></TABLE>
That is good to chip. You have to run a knock sensor thou. P28 = no knock.
That rpm limiter is a little high (for the chip)
Guest
Posts: n/a
damn thanks a ton for that dizzy diagram - that saves a headache or two for me
So i was just over and my buddies garage and we noticed alot of wires need to be extended, but i think all of the plugs are going to end up matching up. Alot of the wires' colors are different, but im just going to repin the dizzy and give it a whirl.
i was also thinking of chipping the ecu, but have heard that you can really screw up the ecu easily, but exactly how difficult is this "chip" to install? i cant see it being all that difficult.
i definatley agree with ek2121 about the rev limiter though... i dont see why youd want it much higher than stock unless youve got headwork done - be careful man
So i was just over and my buddies garage and we noticed alot of wires need to be extended, but i think all of the plugs are going to end up matching up. Alot of the wires' colors are different, but im just going to repin the dizzy and give it a whirl.i was also thinking of chipping the ecu, but have heard that you can really screw up the ecu easily, but exactly how difficult is this "chip" to install? i cant see it being all that difficult.
iLUVmyHONDAcura
Jul 16, 2005 09:58 PM
SPOONfdEK
May 27, 2003 06:32 PM
