k24 and the honda element
Old Aug 11, 2004 | 03:58 PM
bub838's Avatar
Default k24 and the honda element
i cant for the life of me find the engine code for the honda element. i go on there forums but it doesnt seem like they're too interested in that sort of thing.
all ive found is that its a 2.4L i-vtec engine. and it looks like a kseries motors, so i figure its a k24...
but why is it only 160 hp while the k24 in the tsx is 200. the comp is also higher in the tsx. whats the difference in the two engines?
Old Aug 11, 2004 | 04:27 PM
JDMotive's Avatar
Default Re: k24 and the honda element (bub838)
its a k24a something and uses the same head design as the base rsx/civic si,which is why it only has 160hp.The tsx is basically a 2.4l rsx engine which is why it has 200hp.
Old Aug 11, 2004 | 05:16 PM
v4lu3s's Avatar
RTFM
the tsx also revs a lot higher and has drive by wire throttle activation.
Old Aug 11, 2004 | 08:34 PM
bub838's Avatar
yeah, thats why itd seem to be really hard to swap a tsx k24 into a civic or somthing. cuz of the throttle by wire.
so, its basically a rsx k24 kinda.
Old Aug 11, 2004 | 09:47 PM
2FastxEg's Avatar
k24a4
Old Aug 12, 2004 | 01:15 PM
dwolsten's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">the tsx also revs a lot higher and has drive by wire throttle activation. </TD></TR></TABLE>
I'm just curious; what difference does it make that it has drive-by-wire? This shouldn't affect the power output. Also, what's the point of DBW anyway? How hard is it to install a simple cable from the accelerator pedal to the throttle body in a FWD car? I can understand it in a mid-engine car like the NSX where the cable has to travel under the car, but in a regular FWD car, it's only a couple feet long.
Old Aug 12, 2004 | 03:53 PM
v4lu3s's Avatar
RTFM
well you can swap on a diff intake manifold and throttle body since the amount of fabrication to modify a throttle body that is not designed to run with a cable will make it more effort than it is worth.
and in the end why not jsu swap on an rsx-s or integra-r head and get the best head and manifold of all from the factory?
BoltonGSR
18
Dec 10, 2008 05:02 PM
SoullessJapaneseMachine
Nov 6, 2007 03:53 PM
B16aDasher
227
Dec 4, 2006 05:35 PM
SiReflex
Sep 5, 2005 04:38 AM
6SPD_EK
15
Nov 2, 2001 10:47 AM
