Help
Old Nov 30, 2001 | 10:05 AM
erikgsr's Avatar
New User
Default Help help with Driveterain Problem
Hi guys need some help. My car is making a continous clicking(popping) sounds. when I turn left only. The sound alomost sounds like a popping sound. Im thinking its probably the axles, could it be the cvjoint?? It also makes one popping sound when I press the brakes, but it is not constant, just sometimes. Any help will be greately apprecaited. Thanks guys
Erik
[Modified by erikgsr, 8:37 PM 11/30/2001]
[Modified by erikgsr, 8:38 PM 11/30/2001]
Old Nov 30, 2001 | 10:08 AM
Back in Black's Avatar
Rather OG
Default Re: Help (erikgsr)
CV
Old Nov 30, 2001 | 10:09 AM
sackdz's Avatar
Try to be more descriptive with your titles. 'Help' is not likely to get you as much help. Check your cv boots and make sure there's no cuts or tears. What is your mileage?
Old Nov 30, 2001 | 11:37 AM
erikgsr's Avatar
New User
Default Re: Help (sackdz)
Thanx for the Help Guys. there is 62K miles on the car, is there any way to see whether its the CV or axle?Thanx
Old Nov 30, 2001 | 11:57 AM
STOLEN - ITR 98-0652's Avatar
Default Re: Help "My Car makes a clicking noise when I turn left!" (erikgsr)
Most likely, it's the outer CVJ. Just reach your hand around to the boot... if you get greenish grease on it, it's torn and probably contaminated.
You'll need to disassemble to be sure, but the order of magnitude goes like this: boot / CVJ / Axle Shaft. Only rarely will a damaged CVJ mangle an axle. If you catch it early, it my just need the boot and grease replaced.
How long has it been clicking?
Old Nov 30, 2001 | 12:01 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: Help "My Car makes a clicking noise when I turn left!" (ITR 98-0652)
If it sounds like you are constantly running over some cans or like empty coke cans are rolling down a hill, it's the CV joint
Old Nov 30, 2001 | 12:17 PM
Mike M's Avatar
Founding Member
Default Re: Help "My Car makes a clicking noise when I turn left!" (RealTypeR)
CV
Old Nov 30, 2001 | 06:59 PM
erikgsr's Avatar
New User
Default Re: Help "My Car makes a clicking noise when I turn left!" (TypeRmsm)
Thanx guys!!! your all great. Mike Thanx. Any ideas on the cost of repairs? Just so i know, if it is the Cv. Mike are you open tommorow? Ill give you a call.
Thanx erik
[Modified by erikgsr, 4:00 AM 12/1/2001]
