camber kit question
Old Aug 11, 2004 | 12:30 PM
jerm001's Avatar
Default camber kit question
How much of a drop would I have to be at before you would recommend getting a camber kit to prevent wear on the tires?
Old Aug 11, 2004 | 12:38 PM
Chicano's Avatar
Default Re: camber kit question (jerm001)
Once you go under 2" then you will start having camber problems...so usualy a good height is 1.75" all around...I had that with my 17" on my civic and the camber was fine.
Old Aug 11, 2004 | 01:31 PM
jerm001's Avatar
so I should be fine with 15" rims and a 1.75" drop?
Old Aug 11, 2004 | 01:37 PM
Chicano's Avatar
Default Re: (jerm001)
Yeah you'll be fine
Old Aug 11, 2004 | 01:39 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (skaterguy)
toe is what will kill your tires. but you should be fine with a 1.75" drop.
Old Aug 11, 2004 | 01:45 PM
TallAssFilipino's Avatar
Default Re: (AzntaggeR)
Keep an eye on how your tires wear.
Old Aug 11, 2004 | 01:48 PM
Chicano's Avatar
Default Re: (TallAssFilipino)
Don't forget to rotate
Old Aug 11, 2004 | 01:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerm001 &raquo;</TD></TR><TR><TD CLASS="quote">so I should be fine with 15" rims and a 1.75" drop?</TD></TR></TABLE>
On my girlfriend's Civic, she has 15"s with just about that same drop if not higher. Even on her Ingals set-camber, she wears just slightly on the insides.
Old Aug 11, 2004 | 01:59 PM
jerm001's Avatar
"On my girlfriend's Civic, she has 15"s with just about that same drop if not higher. Even on her Ingals set-camber, she wears just slightly on the insides"
SO your saying I will need a camber kit?
Old Aug 11, 2004 | 02:07 PM
Well, base on his opinion and on what I've seen, decide between the two. Most importantly, just notice how your tires wear. You should be able to tell.
Old Aug 24, 2004 | 11:45 PM
jerm001's Avatar
its kind of a money thing, If I need a camber kit I'll have to wait a while till I get some more money, because I only have enough for rims plus tires, and I already have shocks and coilovers, if I need a camber kit then I'll probably just roll on the stock steelies for a while
Old Aug 25, 2004 | 12:09 AM
LSzar's Avatar
dont forget to get an alignment after you get the camber kit in
d17civic
Honda Civic (2001 - 2005)
Aug 21, 2008 05:32 PM
SF_EF8
Suspension & Brakes
Mar 30, 2006 12:05 PM
mdjplay
Jul 8, 2003 12:28 PM
SOHC_MShue
Jun 9, 2003 11:03 PM
ayacht
Oct 11, 2002 07:09 AM
