degree wheels?
Old Aug 11, 2004 | 12:07 PM
civicross's Avatar
Default degree wheels?
Does anybody know who makes a degree wheel adaptor for b series cranks?
Old Aug 11, 2004 | 03:08 PM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Default Re: degree wheels? (civicross)
Do you already have a degree wheel and just want an adapter? Or are you looking for both a degree wheel and adapter? Making a DIY degree wheel is pretty easy. Just print that graphic onto stickyback, put it on plexi/sheetmetal, cut, drill, and you're done.
Old Aug 11, 2004 | 06:51 PM
IN VTEC's Avatar
Bore out the adapter so that you can get the M14 bolt through the hole.
Then use a piece of brass wire from the hardware store or a coat hanger for the pointer. Use a bench grinder to sharpen the end to a fine point. Graduate the point very gently so that it doesn't slope too steeply. That'll make it easier to see where you're at on the wheel.
Old Aug 12, 2004 | 05:10 AM
civicross's Avatar
Default Re: degree wheels? (IN VTEC)
does anybody make a bolt on crank adapter so I can bolt the three holes to it or with a crank socket?
Old Aug 12, 2004 | 05:22 AM
tjbizzo's Avatar
I forgot to mention, you can also resize and print just the outer edge of the wheel with the degrees on it and stick that to your pulley. No muss, no fuss, and if you clean the pulley well enough it's semi permanent.
s13hero
Oct 16, 2009 11:06 PM
s4play
Aug 6, 2009 06:47 AM
aleks77
Apr 25, 2009 09:50 AM
Mr. Vapor
Feb 26, 2006 02:31 PM
Dorikamu
Oct 31, 2002 05:19 PM
