help me rid the last check engine light
Old Aug 11, 2004 | 10:56 AM
alexb16hb's Avatar
Default help me rid the last check engine light
ok it pertains to the oxygen sensor. The car is a 1995 civic cx the motor is a jdm b16a. Now converting from 1 wire o2 to 4 wire o2. I know where the wires go but on the white wire I was told it needed to be shielded (wire wraping around the white wire) where do I connect the shielded wire to.
sorry if any confusion. Hope some one can help me out on this
Old Aug 11, 2004 | 03:29 PM
ryanplayjoint's Avatar
Default Re: help me rid the last check engine light (alexb16hb)
I'm not sure what your asking but, a four wire o2 has two wires for the heater circuit and two for the signal circuit. The shield wraps around the signal wires so the ecu gets a clean signal with no electomagnetic interferance. On a honda the sheild around the signal wire is sent to a ground to ground out any electromagnetic induction. Hope that helps
Old Aug 11, 2004 | 07:01 PM
smart monkey's Avatar
no real need to shield but the white is the signal and just add the other three.
Old Aug 16, 2004 | 10:58 AM
alexb16hb's Avatar
Default Re: help me rid the last check engine light (smart monkey)
i will give that a try and ground the shielded part of the wire. It just doesent make sense that as soon as I turn my car on the check engine light pops on and I have dissconnected the battery to clear the code. Thanks
immorality
Sep 30, 2008 10:09 AM
hksdrager
May 11, 2007 07:55 PM
SuperDuude
Jul 17, 2004 04:25 PM
sherman
Mar 17, 2003 06:04 PM
NO2CIVIC
Oct 30, 2002 06:21 PM
