filling in stock spoiler holes
Old Aug 11, 2004 | 09:29 AM
s1ngle's Avatar
Default filling in stock spoiler holes
anybody done this? how did you do it?
i was given one suggestion of using fiberglass on the underside of the trunk lid, then bondo'ing the top.
is there anything easier, where i dont have to mess with fiberglass?
Old Aug 11, 2004 | 09:35 AM
s1ngle's Avatar
Default Re: filling in stock spoiler holes (EeeJaySixxx)
really?
I dunno, i heard that fiberglass resin is some pretty wicked crap and will permanently adhere to anything you stick it to, and dries nice and waterproof.
Old Aug 11, 2004 | 09:43 AM
s1ngle's Avatar
yeah, the wiring hole is a bigger one. the others are pretty small. Heh, my boss has some spare CF sheets laying around, i should just do it bling style with that. lol.
Any more suggestions?
Old Aug 11, 2004 | 09:46 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: filling in stock spoiler holes (s1ngle)
the correct way to do it is either weld the holes closed or weld a flat piece of thin metal, grind it, bondo, etc.
s1ngle's Avatar
Default Re: filling in stock spoiler holes (vtecb20coupe)
ah, too bad i am welder-less
Old Aug 11, 2004 | 10:09 AM
s1ngle's Avatar
how have other people on the board done it without a welder? i'm sure many people have.
Old Aug 11, 2004 | 10:42 AM
john666's Avatar
ive seen duct tape, electric tape, or plastic vinyl sticker type stuff put on, that matches the car color to hide those holes..
Old Aug 11, 2004 | 12:33 PM
s1ngle's Avatar
Default Re: filling in stock spoiler holes (john666)
ugh, thats gawdy. putting vinyl stickers over holes. haha
Old Aug 11, 2004 | 12:37 PM
Chicano's Avatar
My friend bought some bondo from the hardware store, sanded the hole surface smooth and then he just pasted the bondo over the holes and let it dry, and then re-sanded it and it was flush.
Old Aug 11, 2004 | 01:05 PM
antiJDM's Avatar
i currently use electrical tape.
Old Aug 11, 2004 | 08:15 PM
s1ngle's Avatar
Default Re: filling in stock spoiler holes (skaterguy)
wait, how the crap do you put bondo over holes without somehow having a backing? that crap will just glop through the holes and fall into my trunk fool!
Old Aug 11, 2004 | 08:20 PM
eastbay92cx's Avatar
Just like other people said, welding the holes shut is probably the best (only) way to do it, but the fiberglass method seems the next best thing imo. Good luck.
Old Aug 11, 2004 | 09:12 PM
naturelovindc2's Avatar
Default Re: filling in stock spoiler holes (eastbay92cx)
After taking the wing off of my gsr, I put masking tape over the holes on the top, put that metal mesh(the **** that comes with Bondo) over the holes on the bottom, and smeared bondo through the mesh on the bottom. The next day I pulled the tape off the top and it was damn near perfect, except for the fact that all the holes were ******* pink and my car is white. I used a little Bondo on the top to fill any imperfections, sanded it smooth, threw on a coat of white primer, then some white pray paint ande it looked fine.
Old Aug 12, 2004 | 05:04 AM
s1ngle's Avatar
Default Re: filling in stock spoiler holes (naturelovindc2)
good idea. thanks.
Old Aug 12, 2004 | 05:11 AM
ubercerealkiller's Avatar
fiberglass is pretty easy to work with, its just a bitch in a half when it gets on you, cause its itchy eeek. but yah id probably just fiberglass it for backing, and spread bondo over the top, sand it smooth, and paint it. probably wouldnt take long at all, just dont get that **** in your trunk -_-
but if you REALLY dont wanna mess with fiber glass, then just do like that other dood said and get some thin wire mesh and bondo over it on the underside for support
and then after it cures put it on the top side, sand it smooth and paint and you should be good to go.
Old Aug 12, 2004 | 06:03 AM
s1ngle's Avatar
Default Re: filling in stock spoiler holes (ubercerealkiller)
good input. I think i will try some fiberglass. i'm gonna take the trunk off and mask it and stuff. hopefull i won't make a mess.
Old Aug 13, 2004 | 04:25 AM
if you've never worked with glass before, MAKE SURE you dont put too much of the hardner stuff in the resin, or you'll regret it LoL, **** gets hot! we made a paper cup smoke up and stuff, it was funny
Old Aug 13, 2004 | 05:23 AM
IVI's Avatar
IVI
when they did mine i was told by 1 shop that they couldnt do it because it would later detiorate
another shop did it for me and it looks like they sprayed some type of foam that hardened under the trunk black in color and they bondo'd the top. i guess the foam tar thing under the trunk is to prevent it from somehow opening or messing up? no idea about body work.
Old Aug 13, 2004 | 08:04 AM
antiJDM's Avatar
JB weld...just dont coat it on you'll have to sand it away...
Old Aug 13, 2004 | 08:30 AM
jolt-tsp's Avatar
Default Re: (2thousandcivic)
jbweld a small peice of aluminium to the underside of the whole, bondo/fiberglass on top. Plugs are quicker though
Old Aug 14, 2004 | 03:32 PM
s1ngle's Avatar
Default Re: (jolt-tsp)
plugs? explain.
crazyhouse2011
14
Jun 7, 2014 01:22 PM
hondadxcoupe
Paint and Body
Oct 15, 2008 06:14 PM
cilvia
Paint and Body
Aug 31, 2007 08:03 AM
cloudx71
Mar 27, 2005 09:15 PM
lilbastrd
Honda S2000
57
Mar 8, 2005 09:16 PM
