How long a stock Engine will last?
Old Aug 11, 2004 | 07:33 AM
Jaded God's Avatar
Default How long a stock Engine will last?
Does anyone know if lets say I get a 96-00 Civic in that range and it has close to 100+ on the original motor or a bit more miles on it if it is worth it?
I have around 4,000-5,000 max to spend and my heart is set on an Acura teggie or a Civic... Mainly the Civic. I know the engines tend to get to 200k if maintained right. I am just wondering if I will have to be doing a lot of maintanence, thanks.
*Would post for WTB in classifieds but I can't since I am a trial user right now. I am located in Michigan.
Old Aug 11, 2004 | 07:46 AM
NineTwoSi's Avatar
Default Re: How long a stock Engine will last? (Jaded God)
Dude, don't even worry about it if you check everything out and it's all good... You can always do a cheap motor swap if something goes wrong... d-series motors are a dime a dozen!
Old Aug 11, 2004 | 08:02 AM
blackeg's Avatar
Default Re: How long a stock Engine will last? (I Am Jack)
i just bought a 97 hx with a stock motor and 191,000 miles. it doesnt leak or burn anything, and it compression tested at like 190 for all 4 cyls. its as healthy as could be.
Old Aug 11, 2004 | 08:04 AM
crx_88_si's Avatar
buy a car w/ a dead motor for like 500 to 1000 then swap the motor w/ a b-series
Old Aug 11, 2004 | 08:09 AM
smithenhiven's Avatar
11:11
If you change the oil regularly, and perform the routine maintenance, you should get A LOT of life out of a civic motor. My friend has a 96 DX that he uses for his daily driver back and forth to work almost 200 miles a day. It's got 300K on the original motor, and it still runs great.
Old Aug 11, 2004 | 08:17 AM
turbotime's Avatar
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">buy a car w/ a dead motor for like 500 to 1000 then swap the motor w/ a b-series </TD></TR></TABLE>
Old Aug 11, 2004 | 08:25 AM
tominos's Avatar
Default Re: (turbotime)
it's all a matter of whether or not the car was taken care of or not.
Old Aug 11, 2004 | 08:28 AM
Deemeetree's Avatar
Electrician
Indeed, if romped on, it won't last 20k. But if it was taken care of, babied, routine maintenence, etc...etc...etc...these motors will last to 300k or more.
Old Aug 11, 2004 | 08:29 AM
handa's Avatar
Default Re: (tominos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tominos &raquo;</TD></TR><TR><TD CLASS="quote">it's all a matter of whether or not the car was taken care of or not. </TD></TR></TABLE>
the more you take care of it (oil change, maintenance, etc.), the longer it last...that's all to it.
Old Aug 11, 2004 | 09:11 AM
Jaded God's Avatar
Yea see my problem is I don't know mechanics well and an engine swap would be hard for me, near impossible with my knowledge.
If the car has had one owner and paint and everything looks brand new then it was taken car of.. So think just regular oil changes and so what will give me atleast 50 thousand more miles?
Old Aug 11, 2004 | 09:25 AM
JimmyAtlantis's Avatar
Default Re: (Jaded God)
My car has 148,000 miles (d15b7) and I autocross at least 2 weekends a month. Never a problem. I burn about 1/2 quart of oil between changes. It's nothing to worry about and easily fixed.
Old Aug 11, 2004 | 10:34 AM
jmk2888's Avatar
I had about 342,000 Miles on my D15B7 before I swap it out.
They last pretty long, if you do all the regular maint.
Old Aug 11, 2004 | 10:47 AM
Jaded God's Avatar
Well I probably won't be racing so I will leave in the stock VTECH engine. Just do some interior mods and add some aftermarket rear lights *euros* nothing big.. So I really just need to know if it is worth it to buy a 96-99 Civic that has in the 100K miles on the stock engine for the 4 grand - 5 grand money mark... Or if I should just buy a ford POS like a contour for the same price for like a 2000 contour with 60 K miles on it???
Old Aug 11, 2004 | 10:57 AM
Slopoke's Avatar
If reliablilty is a big deal to you, get the honda.
I would rather buy a 200K mile civic than a 60K mile contour.
If maintaned right, the biggest thing you will need to do is the timing belt.
Since the T belt and water pump should be replaced around 100k miles, make sure it's been done on the civic you want to purchase. If not tell them you want to deduct that from the price (a dealer will charge you around $500).
I've owned 2 hondas with close to 250K miles on them. Both only required regular maintenance(T belt, water pump, oil and fluid changes, spark plugs, cap and rotor, etc).
Old Aug 11, 2004 | 11:00 AM
Street Ghost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaded God &raquo;</TD></TR><TR><TD CLASS="quote">Well I probably won't be racing so I will leave in the stock VTECH engine. Just do some interior mods and add some aftermarket rear lights *euros* nothing big.. So I really just need to know if it is worth it to buy a 96-99 Civic that has in the 100K miles on the stock engine for the 4 grand - 5 grand money mark... Or if I should just buy a ford POS like a contour for the same price for like a 2000 contour with 60 K miles on it???</TD></TR></TABLE>
Don't waste your money on mods (ie. Euros) if you are going to have it as a daily driver, etc. You should go buy a compression tester and take it with you when you go look at the Civic and do a compression test. That way, you will have an idea of how well the motor is doing and what not. Incase you don't know much about compression tests, generally, the numbers should be within 10% of each other across all four cylinders. Good luck.
BTW, it's VTEC, not VTECH.
Old Aug 11, 2004 | 11:06 AM
JinDIESEL's Avatar
Default Re: (JDM Ninja)
buy a type R
Old Aug 11, 2004 | 11:56 AM
Jaded God's Avatar
I didn't mean to add the "H" I know it is a VTEC.
And to Jim... I don't have the money to buy a damn Integra Type R. And I know you have all seen the thread with the 16 year old crashing his teggie... I get what your trying to say, that I can't drive or I am a noob.
Why do you have to be an ***? First of I can drive, I don't know much about mechanics though.
Old Aug 11, 2004 | 12:11 PM
rentacop's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaded God &raquo;</TD></TR><TR><TD CLASS="quote">IFirst of I can drive, I don't know much about mechanics though.</TD></TR></TABLE>Yeah im sure you can
no ones been an *** to you, quit whining.
well, no one until i decided to post..
Old Aug 11, 2004 | 12:17 PM
tominos's Avatar
Default Re: (rentacop)
if you don't know much about mechanics, you can bring the car to a reputable shop and they can check it out for you, will cost you some money though. but it's worth the peace of mind, imo.
Old Aug 11, 2004 | 06:30 PM
cuppie1975's Avatar
put it to you this way. my mom's 99 LX has 266,000 DELIVERY miles on it. hardly uses any oil, runs great. all the thing cares is that I change its oil every 3,000 miles or so. It practically can't be broken.
Old Aug 11, 2004 | 07:21 PM
kaoss_11's Avatar
B A N N E D
Buy a cheap car and get a good swap. Cheap in price.
Old Aug 11, 2004 | 07:41 PM
Soccerking3000's Avatar
Default Re: (kaoss_11)
maybe he meant get a type-r MOTOR which you could for the amount of money you have, as stated buy a 92-95 with a blown motor, and put a gsr or type-r motor in and be a sleeper, it would be a lot of fun to drive and you still get the honda reliability
Old Aug 11, 2004 | 08:24 PM
CivicVX94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Am Jack &raquo;</TD></TR><TR><TD CLASS="quote">d-series motors are a dime a dozen!</TD></TR></TABLE>
lol yeah, read my post in the classifieds then say that
i've been looking forever for a D16z6 and I'm not cheaping out either, it's just everyone's been flaking.....
coryrichard93
Mar 5, 2012 06:47 AM
BlitzSix
10
Oct 14, 2008 08:50 PM
so simple
Jul 18, 2007 08:50 AM
GS-Rdriven
Jul 19, 2004 03:02 PM
ocdcivic
Oct 24, 2003 11:24 AM
