Type R wiring harness: ? plug goes to ? sensor...
I have a 93 Civic CX with a D16Z6 already swapped in it.
Awhile back I swapped in a B18C1 I have during the weekend and it ran strangely and through a bunch of codes, despite the fact I know that everything is in working order. I took the motor out to try again at another time. I need to do this soon. The motor is a 97 B18C1 with skunk2 intake manifold, and I am using a Type R wiring harness on it.
I would like to know exactly what wires go where. In other words... what colored wires go to the MAP sensor, TPS, Air Intake Temp sensor, IACV, etc... I have no diagram to work from so I am basically guessing as to what plugs in where. And it seems like some of the wires don't reach, or need to be extended...but I don't want to be cutting up the wrong wires. So for all you hybrids or Type R owners out there...it would be a huge favor but could you help me out with what color wires go where? Thank you so much guys.
The sensors are labelled.
#1 = TPS sensor
#2 = EACV
#3 = MAP sensor
#4 = IAT sensor
All I need to know is what the colors on your type R harness are that go to the corresponding sensors. Thank you to anyone who doesn't mind taking a few minutes to check this...seeing as I don't know any Type R owners myself.
RuffRhyno
Aug 13, 2004 09:37 AM
