VAFC owners
Old Aug 10, 2004 | 08:43 PM
tianporn's Avatar
Default VAFC owners
Hi, today I was just reving the car in neutral and I reved it past VTEC crossover point a couple of times. On my VAFC it showed only VTo as "on" but VTi was "off"
Aren't both of them meant to be "on" when reving it past VTEC point in neutral?
I also noticed when driving, there is a slight lag between VTo "on" and VTi "on"
My VAFC is running initialized settings so its running stock spec. Shouldn't both VTi and VTo come on at the same time???
Im puzzled.
Cheers
Old Aug 10, 2004 | 10:04 PM
Sack Master's Avatar
Default Re: VAFC owners (tianporn)
VTO is when your AFC turns the vtec on and VTI is when your ecu is trying to turn the vtec on. Thats all it is. Just an ecu output reading. Means nothing.
Old Aug 10, 2004 | 11:25 PM
tianporn's Avatar
Default Re: VAFC owners (Sack Master)
Hmm so the VAFC is running initialized specs so the VTo kicks in at 5800rpm. Shouldnt the ECU be kicking VTEC in at 5800rpm as well?
Oh Ive got a B16a
Old Aug 11, 2004 | 12:31 PM
RedBadge's Avatar
No the vafc takes over the vtec engagement point activation. so all that really matters is vto... the ecu still tries to turn on vtec at the stock setting but it wont, (fuel curves ignition timing... or whatever other ecu changes to the engine still occur however) except the vtec lobe being put to work on the cam.
xelloss
Engine Management and Tuning
Oct 28, 2008 09:35 AM
Power Rev Racing
Oct 16, 2005 06:10 PM
BlackOnBlackTeggie
Nov 30, 2003 06:25 PM
genetsang
Aug 20, 2003 01:54 PM
EJK
Apr 14, 2002 12:55 PM
