whats included in with a greddy turbo timer?
Old Aug 10, 2004 | 06:51 PM
p1ccoloz's Avatar
Default whats included in with a greddy turbo timer?
i just bought one off ebay and was wondering if got everything i was supposed to. i basically got just this i looked at the instructions and there seems to be somethings im lacking. can anyone confirm?
Old Aug 10, 2004 | 06:57 PM
B18 CYA's Avatar
theres another harness that plugs into that that goes to the ecu and another harness for ur speed thingy which tells how fast ur going....
11psiTurboSI's Avatar
Default Re: whats included in with a greddy turbo timer? (p1ccoloz)
there's another wiring harness that connects to the end and a smaller wiring harness that connects for the vss and e-brake
Default Re: whats included in with a greddy turbo timer? (9psiTurboSI)
lol we replied at the same time!
Old Aug 10, 2004 | 08:51 PM
p1ccoloz's Avatar
thanks alot!
Old Aug 19, 2004 | 08:30 PM
p1ccoloz's Avatar
so theres nothing included that plugs into the big plug?
Old Aug 20, 2004 | 12:45 AM
p1ccoloz's Avatar
ttt
Old Aug 21, 2004 | 04:22 AM
p1ccoloz's Avatar
ttt
Old Aug 21, 2004 | 05:29 AM
thermal's Avatar
Ok, these are what should be inside that GReddy turbo timer box:
-the unit itself
-a big clip that clips on to the unit clip harness
-a small clip that taps on to your VSS and e-brake
-vacuum hose (I think)
-manual
The only wire that should tap into your ECU is the VSS... nothing else.
Remember that this is not a "plug and play" unit. You will tap the wires as per the instruction. You also have no need for the VSS and e-brake wire if all you desire is the basic countdown function.
Old Aug 23, 2004 | 10:29 PM
p1ccoloz's Avatar
Default Re: (thermalfi'd16)
according to the seller the big clip isnt included.... is he full of ****?
Old Aug 25, 2004 | 10:06 AM
p1ccoloz's Avatar
Default Re: (p1ccoloz)
ok this has been beaten into the ground but im getting mixed responces... so am i getting had my this seller?
Old Aug 25, 2004 | 10:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thermalfi’d16 &raquo;</TD></TR><TR><TD CLASS="quote">Ok, these are what should be inside that GReddy turbo timer box:
They don't come with a vacuum hose
Old Aug 25, 2004 | 10:18 AM
ITRpwrdEG's Avatar
correct, there is no vacuum hose whatsoever. That comes with the Greddy Profec B Spec2 boost controller. What is missing from yours are those two other clips with wire leads coming off of them to be connected to their proper pinouts. And if you didn't even get a manual, then wow. But I would complain until I got the right stuff. GL
Old Aug 25, 2004 | 11:00 AM
p1ccoloz's Avatar
humm well i have the unit and the clips for the vss and ebrake. im just missing the part that connects to the "main" or big clip?
Old Aug 25, 2004 | 11:03 AM
yup u have a big connecter that clips to the end that you hard wire to the car
kcjohnnyboy
Jan 17, 2006 09:42 AM
Turbo_Mike
Aug 11, 2005 10:22 AM
Turbo_Mike
May 1, 2005 08:29 AM
phreakmang
10
Jul 8, 2004 07:23 AM
