whats included in with a greddy turbo timer?
i just bought one off ebay and was wondering if got everything i was supposed to. i basically got just this i looked at the instructions and there seems to be somethings im lacking. can anyone confirm?
Re: whats included in with a greddy turbo timer? (p1ccoloz)
there's another wiring harness that connects to the end and a smaller wiring harness that connects for the vss and e-brake
Ok, these are what should be inside that GReddy turbo timer box:
-the unit itself
-a big clip that clips on to the unit clip harness
-a small clip that taps on to your VSS and e-brake
-vacuum hose (I think)
-manual
The only wire that should tap into your ECU is the VSS... nothing else.
Remember that this is not a "plug and play" unit. You will tap the wires as per the instruction. You also have no need for the VSS and e-brake wire if all you desire is the basic countdown function.
-the unit itself
-manual
Re: (thermalfi'd16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thermalfi’d16 »</TD></TR><TR><TD CLASS="quote">Ok, these are what should be inside that GReddy turbo timer box:
They don't come with a vacuum hose
correct, there is no vacuum hose whatsoever. That comes with the Greddy Profec B Spec2 boost controller. What is missing from yours are those two other clips with wire leads coming off of them to be connected to their proper pinouts. And if you didn't even get a manual, then wow. But I would complain until I got the right stuff. GL
humm well i have the unit and the clips for the vss and ebrake. im just missing the part that connects to the "main" or big clip?
