Sideskirt question 99-00 civic
Old Aug 10, 2004 | 05:41 PM
2000turbosi's Avatar
Default Sideskirt question 99-00 civic
have a 00 civic si...i have a short question...tried searching couldnt find too much on the subject...anyways...got into an accident...my sideskirts were messed up bad...a buddy of mine gave me his sideskirts off his 98 civic coupe ex the plastic kind, black, etc...i need to get them painted electron blue....will they look ok painted?.... or is that plastic not meant to be painted...will it look like ****?....thanks for any help....
Old Aug 10, 2004 | 05:48 PM
EX-T's Avatar
Default Re: Sideskirt question 99-00 civic (2000turbosi)
There is not a difference between you side skirts and the ones off of the 96-98.
Old Aug 10, 2004 | 06:38 PM
93Civac's Avatar
Agreed, as long as they are properly prepped, there should be no problem and they will look good.
Old Aug 11, 2004 | 04:28 AM
Default Re: (93Civac)
thanks for all the help...
much obliged
Old Aug 11, 2004 | 04:32 AM
=GAME='s Avatar
Default Re: (2000turbosi)
youll need to hit it up with a scuff pad or sandpaper or else the paint wont stick.
Old Aug 11, 2004 | 05:47 AM
NickW's Avatar
Default Re: (=GAMEOVER=)
I painted my sides and aside from rock chips they are fine. I washed them, sanded them with a fine grit (so no grooves in the soft plastic), primered, sanded, primered alil more and painted.
Done deal, look good.
Old Aug 11, 2004 | 06:29 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000turbosi &raquo;</TD></TR><TR><TD CLASS="quote">or is that plastic not meant to be painted...will it look like ****?</TD></TR></TABLE>
The plastic can be painted, but the thing you have to be careful of is the fact that the vinyl is textured (if the 98's are the same as my 00 black ones). If not done correctly, you will see the texture of the plastic through the paint, so it won't be smooth.
Also, the texture may make it look like the color doesn't match exactly since the light will reflect off of it differently than the smooth ones. A professional should be able to do it up for you though, but for that price, you may just want to look into replacing them with OEM that come painted from Honda.
Old Aug 11, 2004 | 07:05 AM
Default Re: Sideskirt question 99-00 civic (EX_AutoXer)
yea ive thought about that as well....my brother works at honda....can get them for me for 160....but i got these sideskirts for free....any i have a buddy at the shop...he will prob. give me a real good deal...so its a toss up....not sure what im going to do yet...thanks for the help though
Old Aug 11, 2004 | 07:07 AM
I meant i have a buddy at the body shop who can paint them cheap for me...wanted to make that clear...does anybody have pics i can look at?....
thanks again
Old Aug 11, 2004 | 08:52 AM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000turbosi &raquo;</TD></TR><TR><TD CLASS="quote">yea ive thought about that as well....my brother works at honda....can get them for me for 160....but i got these sideskirts for free....any i have a buddy at the shop...he will prob. give me a real good deal...so its a toss up....not sure what im going to do yet...thanks for the help though</TD></TR></TABLE>
i would spring for the OEM painted ones. if you get the black ones professionally painted, it could easily cost you $100, and the paint has a high chance of chipping off over time. better yet, rock black side skirts its jayd33m y0!
Old Aug 11, 2004 | 09:35 AM
Default Re: Sideskirt question 99-00 civic (dantastic)
good feedback...still not sure what im going to do...just wondering if anybody has pictures of the sideskirts painted...that were originally black and plastic?....thanks again
Old Aug 11, 2004 | 09:47 AM
vtecb20coupe's Avatar
B A N N E D
i swear i've seen this question asked at least 5-6 times. there is no difference in the sideskirts. whomever you have paint them, make sure they prep them properly so the paint will stick.
Old Aug 11, 2004 | 09:55 AM
6SPD_EK's Avatar
Default Re: Sideskirt question 99-00 civic (vtecb20coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb20coupe &raquo;</TD></TR><TR><TD CLASS="quote">i swear i've seen this question asked at least 5-6 times. there is no difference in the sideskirts. whomever you have paint them, make sure they prep them properly so the paint will stick. </TD></TR></TABLE>
2nd that...I have had mine painted taffeta white...looks the same if they came from the factory....no need to ask for pictures - case closed - lock this bitch up
EDIT: next time SEARCH!!!!!! "sideskirts" limit to eg+ /del sol forum & click on archive topics....then read any thread that has the word painted, paint, or painting...F'n people (n00bs especially) need to know how to search NOTE - you will get different results when you search "sideskirt" compared to "sideskirts" as well
Modified by adirondackR at 2:38 PM 8/11/2004
Old Aug 11, 2004 | 10:38 AM
Default Re: Sideskirt question 99-00 civic (adirondackR)
like i said in the above post i tried searching...i did click archieve...then i typed "painted sideskirts".....came up with only 12 results....those of which didnt answer all my questions....thats why i posted...you need to chill out....
Old Aug 11, 2004 | 10:45 AM
6SPD_EK's Avatar
using the word "painted" will limit you from topics with the word "paint" & "painting" in the title
using the word "sideskirts" will limit you from topics with "sideskirt" in the title
and of course if you use paint/painting/painted in the title you will probably miss the topic that tells you that 96-98 sideskirts are the same as 99-00...I am try to help you & this forum by keeping the number of repetitive post to a minimum....when you are here for 3+ years seeing the same topics OVER & OVER can be annoying & a waste of valuable space thanks
Old Aug 11, 2004 | 10:48 AM
alright whatever....i found out what i needed to know...thanks everybody...get the post out of here...if it makes you so annoyed....later....i dont even care...
YEAH!
13
Apr 18, 2011 07:51 PM
gigidygigidy
Oct 4, 2007 02:18 PM
kycivicboy
31
Dec 7, 2005 11:16 AM
xoutlawz00x
Dec 21, 2004 06:27 PM
blkgsr03
Nov 4, 2004 09:35 PM
