b16a out of a del sol info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fasthatch8847 »</TD></TR><TR><TD CLASS="quote">does anyone have any info on the b16a out of a del sol...hp numbers and how easy it is to do..if there are alot of aftermarket parts</TD></TR></TABLE>
search..
Easy install if u got the tools, and the dohc vtec linkage.
Theres as much aftermarket **** out for it as any other car/motor.
search..
honda=infinite aftermarket support,del sols came with a B16A3 or a B16A2(96-97) depending on the year. just search and you will get a ton of info
The swap will be a piece of cake. You need the mounts, DOHC VTEC shift linkage from a sol, wire harness, ecu, and the axles.... Either of the B16s that came in the sol have 160 HP. The whole swap will bolt right in. Having a lift available will make the job 100x easier too...
markiebredsol
16
Jul 27, 2003 12:21 AM
