compressions affect on timing?
Old Aug 10, 2004 | 02:22 PM
Race Egr's Avatar
Default compressions affect on timing?
ok im wondering with more compression do u need more timing? Say i have a gsr motor sleeved to 84mm and 9:1 compression. For break in while the motor is still N/A would i need to retard timing? So if I make a base map from the stock gsr map would i wanna take out some timing throughout the whole ignition map?
thanks
Old Aug 23, 2004 | 05:57 PM
DollaR_'s Avatar
Default Re: compressions affect on timing? (NAPIER)
the stock timing map is ok since you lowered the compression and that you are N/A, for boost aplication most lowered it.
Old Aug 23, 2004 | 06:54 PM
SJcivic's Avatar
A good rule of thumb:
If you replaced/expanded/etc anything internal, your timing has changed.
Rich
Old Aug 23, 2004 | 07:26 PM
Race Egr's Avatar
Default Re: compressions affect on timing? (SJcivic)
do you guys have any good tips on tuning timing. Other than just listen for knock is there anyway to just set timing at like a known safe point or do you have to use the dyno graph and look at the power and torque curves. thanks for the help guys
Old Aug 28, 2004 | 01:45 PM
SJcivic's Avatar
Each and every engine is different and a degree or two is the difference between good or bad. I'd make a few calls to Honda shops that are running a very similair setup (or identical) to yours and using that with a bit of guess-timation.
If you have acess to a dyno, you can set it within a few minutes.
Rich
PS. They DO make internal chamber detonations sensors, but the last time I checked the complete kit was somewhere around $5k-$7K...
ohsnapzafingcu
Engine Management and Tuning
14
Sep 28, 2009 07:54 PM
CRXdan
Nov 26, 2004 09:49 PM
b_ron007
Sep 19, 2004 04:22 PM
MintFlavored
Apr 22, 2004 02:59 AM
b00stedbyFastrax
Sep 1, 2002 06:39 AM
