Car runs very rich on hack
Old Aug 10, 2004 | 12:22 PM
MooreBoost's Avatar
Default Car runs very rich on hack
Im running a DOHC ZC, 88 Teg ECU, 14b turbo @ .5 BAR.
I put in the "standard" hack settings, -40 @ 1000 to -36 @ 7500. My car runs very lean at idle with this setting, like 18:1. Previously I had the settings at -29 @ 1000 to -18 @ 7500. These made the car run very rich at WOT like 9:1 but good at crusing around 14:1. I reset to the "standard" setting because it would break up at high RPM from running so rich, and I think its fouling up my plugs.
Is something wrong? Or do I just need to find a median? Would it be best to do this on the street with my wideband or just get it on a dyno ASAP?
Old Aug 10, 2004 | 12:27 PM
toolowsol's Avatar
Default Re: Car runs very rich on hack (tegunderpressure)
turboedit would solve all your problems
Old Aug 10, 2004 | 12:50 PM
MooreBoost's Avatar
Default Re: Car runs very rich on hack (toolowsol)
My ECU cant be socketed. Already tried.
Do I need to remove my stock fuel pressure regulator for the hack?
Old Aug 10, 2004 | 01:06 PM
beepy's Avatar
Your baseline should be:
(Stock injector size)/(New injector size) - .95
Assuming your new injectors are larger than stock.
After you get that right, so that the engine rund stioch. without boost, you can adjust to compensate for boost.
Old Aug 10, 2004 | 07:10 PM
MooreBoost's Avatar
Default Re: Car runs very rich on hack (beepy)
So we have (240/450)-.95 = -.41 . Which would put me back at the "standard" settings which make me run very lean.
Old Aug 10, 2004 | 08:36 PM
Johnyquest's Avatar
So adjust it to somewhere in between the "standard" setting which makes you too lean, and your old setting which made you too rich... and find the right setting which makes it just perfect....
Matt
Morgan Reitz
May 28, 2017 05:40 AM
speedd2286
12
Sep 5, 2005 12:09 PM
redlseg
12
Aug 12, 2005 04:44 AM
CivicRaping
May 4, 2005 11:52 PM
sneakypete
May 29, 2003 02:35 PM
