Wastegate actuator question....
Old Aug 10, 2004 | 10:31 AM
G3NR8's Avatar
Default Wastegate actuator question....
On internal wastegate actuators, are there springs like on external? I have a 10psi WG actuator on mine currently, but I need to lower the boost....
Modified by G3NR8 at 9:49 PM 8/15/2004
Old Aug 10, 2004 | 11:49 AM
beepy's Avatar
Default Re: Wastegate actuator question.... (G3NR8)
Yes, but there is no way to get to the spring.
Old Aug 10, 2004 | 01:18 PM
G3NR8's Avatar
Default Re: Wastegate actuator question.... (beepy)
Thanks
Old Aug 15, 2004 | 05:50 PM
G3NR8's Avatar
Is there any way to test a WG actuator??? I don't know if mine is even opening. It's either not opening, or it is set @10psi. I don't want to boost over 8 psi, so I really can't tell if it is opening or not. I just bought a 7psi actuator (haven't received it yet) but I'd like to know if this one is working before I install a new one.
Old Aug 15, 2004 | 06:13 PM
pngfolife's Avatar
Just apply 7psi of regulated compressed air to the port and see if the actuator is open.
deca
Apr 6, 2005 04:50 AM
60-1
Mar 18, 2004 11:30 PM
hybridb18
Dec 2, 2002 09:29 PM
