intake makes noises
Old Aug 10, 2004 | 06:21 AM
lakizzle's Avatar
Default intake makes noises
i jus installed my damn intake, and when i step on the gas i hear like a cricket sound..its annoying as hell lol...anyone got a clue? The noise sounds like its coming from the filter because its behind the bumper..
Old Aug 10, 2004 | 06:50 AM
EX-T's Avatar
Default Re: intake makes noises (lakizzle)
is it a whistlin' noise?
Old Aug 10, 2004 | 07:26 AM
Redsun's Avatar
The intake pipe might be rubbing against the side of the hole where it goes into the bumper. I had that with mine, but i anticipated it and stuck protecting pads onto the pipe.
Old Aug 10, 2004 | 07:36 AM
mmuller's Avatar
Mad Scientist
Default Re: (Redsun)
sounds like the normal; tuned pipe intake noise.
Old Aug 10, 2004 | 10:20 AM
lakizzle's Avatar
yea its a whistling noise sorta like a cricket lol..but yea i'll try what you guys suggested
Old Aug 10, 2004 | 11:47 AM
vmm's Avatar
vmm
Default Re: (lakizzle)
mine makes a whistling noise too, at around 5 rpm...cuz said cause its tuned rite..i dont mind
Old Aug 10, 2004 | 12:31 PM
Accord6Gen's Avatar
i have the same problem ... mine is caused because the it came with 2 wire ties and 2 rubber pipes, on large one small, the small fits inside the large on and the factory pipe is also a small rubber pipe around the same size but slittly smaller the wire tie does not squeeze the pipe on the factory rubber hose, which causes the wisling noise around mid rpm range (the rubber pips connect the the small outlet on the intake pipe to the top of the engine)
DSBP1
18
Jul 7, 2007 07:51 PM
94lspower
May 3, 2007 05:02 PM
totsie7944
Jul 6, 2004 05:34 PM
h_hydrogen
Dec 5, 2002 10:23 AM
