Clifford blackjax and turbo timers
Been looking into the blackjax and they way I understand it, is that everytime the door is opened a code has to be put in to prevent the system from turning the alarm on. what do you do if you have a 60 second or more turbo timer?
You should not have any issuees with it as Blackjax will only kick in IF you drive the car and used the brakes after you have opened the doors. If you just drive and parked up and leave the car with the TTimer kicks in, the Blackjax would not be activated at all. You follow?
So if teh door is opened, then teh brake is pressed. it knows someone drove off with it, but if you pull up into your driveway, open the door and walk away.. it will see that the car is not moving because you didnt press the brakes and not set the alarm off? is that what you are saying?
ocd
19
Jan 16, 2004 08:41 PM
Hoodwinked
Audio / Security / Video
Dec 26, 2003 07:36 AM
