Shifter
Old Aug 9, 2004 | 10:19 PM
chattownrexer's Avatar
Default Shifter
Hey is it possible that a gsr short shifter with the bend in it will fit my crx?
Old Aug 9, 2004 | 10:29 PM
crexer's Avatar
Default Re: Shifter (chattownrexer)
yep i have a 94+ gsr shifter in my crx. I think the ls and the gsr one are both the same. All you have to do to make it fit is hack about 1/4" off the bottom of the shifter where it goes onto the linkage and use your old crx shifter slide pin and everything bolts up after that. It took me maybe 30 minutes from start to finish. It has a nice bend in it and reduces shift throw maybe 30% and sits about 2 inches lower than the stock shifter. Of course I used an OEM stock integra shifter but your aftermarket short shifter will probably just bolt right in.
Old Aug 9, 2004 | 11:04 PM
Default Re: Shifter (crexer)
what do you mean hack off the end and use the other crx one, thats what i want is the bend and the gsr shiftknob looks really good too....
Old Aug 10, 2004 | 05:56 PM
crexer's Avatar
i didnt mean hack the crx shifter....i meant u had to cut a 1/4" off the gsr shifter where it bolts into the linkage. Take out your crx shifter and compare them. Its very easy to do this. Some people bend their linkage to accept the gsr shifter but I think its better to slightly mod it and use the pin from the crx shifter on the new gsr shifter after you cut 1/4" off. I cant explain it any better than that
Old Aug 10, 2004 | 07:09 PM
skunk2eg's Avatar
go with the gsr shifter, they are really good imo
661rex89si
11
Feb 3, 2009 11:52 PM
xDicktonesx
13
Aug 11, 2005 01:55 PM
crexer
Sep 1, 2003 07:45 PM
jdm169
Mar 6, 2003 09:51 AM
Blue-Civic-Hybrid
Jul 18, 2001 12:32 PM
