Tranny prob q's
Old Aug 9, 2004 | 10:03 PM
RC_SKUBY's Avatar
Default Tranny prob q's
Friends tranny was working fine then all of a sudden it wouldnt go into 1st, 2nd, and reverse. after a little trying it started working fine again for a couple days then it did the same thing again. it works fine now but what could be the problem? any info would be appreciated thanks.
Old Aug 10, 2004 | 11:10 AM
RC_SKUBY's Avatar
Default Re: Tranny prob q's (skuby_do)
ttt
Old Aug 10, 2004 | 02:15 PM
RC_SKUBY's Avatar
Anyone?
Old Aug 11, 2004 | 04:54 AM
JimBlake's Avatar
How does it "not go in"? Does it grind or is it just blocked out? The difference between a dragging clutch & a shot synchro is something you want to feel firsthand...
Usually a dragging clutch will block you out of all gears, not just 1, 2, & R. But reverse doesn't have a synchro in the first place...
Maybe a bent or loose shift linkage? Or bad motor mounts? That way it's like you aren't lined up with the gate when you try to push it into gear.
Old Aug 11, 2004 | 11:37 AM
RC_SKUBY's Avatar
Default Re: Tranny prob q's (JimBlake)
alright thanks for the info ill have him check out his lynkage and mounts. i guess he said it just blocked him out of those gears for a little while.
SoCaLeK
Transmission & Drivetrain
Nov 11, 2008 01:37 AM
`chrisb
Jul 13, 2007 07:55 AM
kemo909
May 20, 2006 04:39 PM
lawlerlaw
23
Apr 21, 2006 09:11 AM
