Help, fast..rad question
Old Aug 9, 2004 | 03:52 PM
Dupes's Avatar
Default Help, fast..rad question
I did a search, didnt find anything...
on my 00 R, when I took off the oem rad, it only had 3 hoses connections.
I bought a replacement rad today, and at the bottom of the rad there are 2 extra nickel piping about 3 inch long attached to the rad... what are they for?
thanks guys
Old Aug 9, 2004 | 03:56 PM
.RJ's Avatar
.RJ
Default Re: Help, fast..rad question (Dupes)
Probably a transmission oil cooler. Just cap them off
Old Aug 9, 2004 | 03:57 PM
Dupes's Avatar
Default Re: Help, fast..rad question (.RJ)
thanks, thats what ill do...
im talking about the ones that are measured on this picture...
http://www.rockauto.com/ref/CA...3.jpg
Modified by Dupes at 9:15 PM 8/9/2004
Old Aug 9, 2004 | 05:17 PM
Dupes's Avatar
no one as encounter this probleme before?
Old Aug 9, 2004 | 05:20 PM
esponet's Avatar
a/t cooler lines. since you have a manual, you don't need them. most radiator companies makes one type of radiator. to fit at and manual.
Old Aug 9, 2004 | 05:30 PM
IVI's Avatar
IVI
Default Re: (esponet)
cooling for the tranny.
i didnt know you can use a radiator if it was off a manual
it had to be either manual or auto.
thats what i was told anyway.
Old Aug 9, 2004 | 07:42 PM
Dupes's Avatar
Default Re: (IVI)
problem solved, thanks guys.
Old Aug 9, 2004 | 10:09 PM
integrasi's Avatar
Default Re: (IVI)
line for turbo???
Old Aug 9, 2004 | 10:15 PM
B2FiNiTY's Avatar
Default Re: (integrasi)
Yeah, as said before, it is for the AT tranny cooler. Block them off as RJ said and you shall be set but I guess you figured it out.
Old Aug 10, 2004 | 03:49 AM
Dupes's Avatar
Default Re: (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, as said before, it is for the AT tranny cooler. Block them off as RJ said and you shall be set but I guess you figured it out. </TD></TR></TABLE>
thats what I did, I blocked them off
Old Aug 10, 2004 | 05:08 AM
ebelp's Avatar
Default Re: (Dupes)
I ran into this problem with the replacement radiator for my old gsr. I didn't have anything to block off the 2 inlets, ,so I just took a length of silicon hose and connected them. Same difference I guess....I never ran into any problems doing it that way.
totec
Mar 24, 2013 08:57 PM
j894
May 25, 2012 08:24 PM
TB123
Feb 21, 2008 03:09 PM
foom1986
Dec 18, 2007 01:16 PM
