Main Relay
I remove that tray that flips down (3 screws), the plastic piece that covers the fuses, and i also remove the hood release latch (2 10 mm bolts). 10 mm wrench removes the main relay.
I got an 88. Yours should be similar.
Are you getting a new one or repairing it?
yea i did it all w/o removing anything but the coin tray...time consuming tho until i borrowed a neighbours small socket wrench.... I bought a new one for $75(cad) @ my honda dealership, i will probably repair the old one tho in case i need to swap again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbender »</TD></TR><TR><TD CLASS="quote"> i will probably repair the old one tho in case i need to swap again.</TD></TR></TABLE>
wow didn't know u could will do that if they ever go bad instead of buying no ones or going to the junk yard to search for one
got like three incase Lucky me I guess
from what i 've gathered you can just re-heat the solder...and add more if necessary to repair it....Spuratic starting, espically when it was warm led me to the main relay...it would sometimes not start 1st time of the day when it was warm out, sometimes it wouldn't start after shutting it off for just a bit, to run into a store or something, as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superhatch »</TD></TR><TR><TD CLASS="quote">What problems lead you to the main relay? I'm having trouble with my gauges going wild with blinkers on, and more wild with lights/brights on and a blinker.</TD></TR></TABLE>
Sounds like a ground problem that or you tapped in some indiglo gauges to you turn signal wire.
2point2
10
Jun 4, 2006 09:25 PM
